Question about HP Compaq dx2250 Microtower - Get 3 desktops for the price of 2 until 123107
Task Manager Disabled
If i Ctrl alt Del my task manager does not show on my list! Is there any quick solution to this??? I have made a Registry Check with Reg Cure and found a few problems. RegCure manage to fix all the problems found but threre is still NO Task Manager when Ctrl Alt Del.
please HELP me with this issue
Thanx...
  • 50 Answers
Try using Ctrl+Shift+Escape This should open the task manager directly. If it does not check that C:\windows\system32\taskmgr.exe exists.
Posted on Jun 03, 2009
Blank screen
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
Tip
Enable the Registry Editor, Task Manager and Folder Options Disabled by Viru
Virus attack is common these days and we often come across the problems like Disabled Folder Options or like Task Manager and Regedit disabled by Administrator. These problems are nothing but virus activities. The virus has infected our system and stopping us from accessing these options.
Pressing keys Ctrl+Alt+Del opens up a dialog saying that “Task Manager has been disabled by your Administrator” whereas you are the Administrator yourself. It becomes very annoying when you think that you can fix this problem by going into the Registry Editor but it doesn’t show up. Even the Folder Options gets disabled.
This problem is generally caused by a virus named “Brontok” but don’t worry just use RRT (Remove Restrictions Tool) that can easily solve this problem. RRT is free and can successfully enable:
1. Folder Options
2. Regedit (Registry Editor)
3. Task Manager
4. Show Hidden Files option
The tool will come more useful if you use it in Safe Mode.
Download RRT
on Nov 17, 2008 | Microsoft Windows XP Professional With...
My task manager is not opening up. i am continuously trying ctrl alt delete. mys os is XP.
download Unhook.ini from norton site. Run it as administartor. It should get fixed.
Cheers!
Sep 06, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Shut off my Dell last night. When to sign in in the morning and when I did the Ctrl, Alt, Delete - nothing happened. is it shot or can i fix it ej
possible fixes:
1) run antispyware and antivirus
2) In XP PRO then try turning the Task Manager Disable facility on and then off again. It should be set to off or 'not configured'.
For turning Task manager On/Off
Start, Run, type gpedit.msc,OK
In left hand pane Double click Admin Options.
Double click System,
Click Ctrl, Alt, Delete.
Then in right hand pane double click Ctrl, Alt, Del. This opens up 'Task Manager Disable/Enable' facility..
Setting on radio buttons should be either disabled or 'not configured' If so select enable (this turns Task Manager Off), Apply, OK.
Oct 09, 2009 | Dell 0Y3740 Keyboard
Left alt key not functioning in pagemaker
If you cannot access your Task Manager when Pressing the Ctrl+Alt+Del, this means you have a virus on your system which has disabled the task manager. If you have a good antivirus like Norton, Kaspersky or McAfee try scanning to detect the virus.
OR
Format your system, but before doing that makesure you backup your data before doing that.
Regards
Sep 16, 2009 | ASUS Eee PC 1000H Laptop
How to enable registry edit & how enable task manager
There is 2 ways to do this.
1) navigate to HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionPolicies. Here open System, DisableTaskMgr, and change Value data to 0, in order to enable Task Manager, or to 1 in order to disable the tool
2) type "gpedit.msc" in the Search box under the Start menu and then launch the tool with elevated privileges, as shown above. Navigate to User Configuration, Administrative Templates; System, Ctrl+Alt+Del Options, Remove Task Manager, and here you can choose between either Enable or Disable the utility
May 09, 2009 | Microsoft Windows Vista Ultimate Edition
Task manager disabled
PRESS
CTRL+ALT AND BY HOLDING THESE KEYS PRESS DEL
Dec 13, 2008 | Microsoft Windows Vista Ultimate Edition
Task manager / registry editing problems
I faced that problem few months back. what i did is reformat my pc. but there is one more way is to create a user from control panel and give that user administartor access.
Try it
Jan 16, 2008 | Microsoft Windows XP Professional for PC
Ctrl+ALT+Del does not launch Task Manager on my MobilePro 900, why?
The Ctrl-alt-del short cut to the Task Manager is not on the MobilePro 900. To bring up Task Manager on the MobilePro 900, hold the "Alt" key and then tap the task bar with the stylus simultaneously. A menu with "Task Manager" and "Properties" will be displayed, select Task Manager.
Sep 14, 2005 | NEC MobilePro 900 Handheld
HP Compaq dx2250 Microtower - Get 3 desktops for the price of 2 until 123107 Logo
74 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
