Question about ASUS Motherboard Striker II Formula
I took my pc apart last night to do some kabinett mods to my antec 900. and put everything back togheter and startet up, everything seems to work but i dont get no picture on my screen, it says no signal input, and my LCD poster says PCI INIT, that message isnt in the error guide so this aint no error right? i have a formula strike 2 motherboard 8800 gtx gpu. what coud my problem be? have checked all the contacts, everything is connected, have moved the gpu to another pci-e slot but no luck. tried to reset bios, with taking the battery out. but same problem
    Scholar:
  • 56 Answers
Best thing to do here is to remove all cards - except for video, and see if the problem persists. If your motherboard has onboard video, then you can try using that and see if the machine will boot up... It might also sound stupid, but check the connectors on you monitor and pc.. make sure you have them connected correctly. I had a problem with dual output video (VGA and Digital). and had to switch over to VGA to get the monitor to work...
Posted on Jun 03, 2009
  • 86 Answers
"No signal input" means that the signal is not making it from your video card to the monitor. Things to try: 1) check your monitor cable to make sure you didn't accidentally bend any pins when you reconnected it. 2) Unplug the monitor for about 5 minutes and then try again. 3) If you are positive that everything is connected correctly and that things are working (you can hear the hard drive and fans spinning up but no video) then you may have somehow killed a component. disconnect everything except the power-supply, video card, 1 stick of ram, the CPU and the CUP fan and see if it you get video there. If you don't, then the next step would be to swap out each of those components left to see what died.
I took a Lefod Mod LF10-1H Pressure Control switch apart and I'm now looking for a diagram on how to put it back together.
You silly person you should not have taken it apart if you are not capable of doing the job
Dec 18, 2015 | Washing Machines
Tip
I found this very useful. I have a brand new F5914-900 and no other solution...
When the brushes stop spinning on a Hoover SteamVac, it can be caused by several things. In order to diagnosis why your brushes aren't spinning, please view the diagnosis solution I have done on Fixya:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
If you have diagnosed your machine, and found that the internal receptacle is not spinning, then you'll now need to replace your turbine. This tip will explain in detail how you'll need to complete this repair.
Here's what you'll need to complete this repair:
- Hoover SteamVac Replacement Turbine Brush Gear (several different parts for different models)
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see-thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to un-clip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before you tighten the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
Chris J.
GoVacuum
on Aug 11, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My GE electric dreyer, DHDSR46EGWW, is making squeaking noise and a grinding noise. My husband took is apart last night and put back together. When he started it the noises came back and he said it...
It could be the rear bearing or if not it have your honey take it apart again and inspect the rear rollers, if they turn freely then inspect the front bearing assy it is on the the door and if it looks worn down then it is allowing excessive pressure on the rest of the unit .
Apr 01, 2011 | General Electric DHDSR46EGWW Dryer
How to put back together a ps3 system
last night when i took apart my ps3 i forgot to take out the game. when i put it back together do i need to put the game back in as i am putting it back together?
Mar 10, 2010 | Sony Playstation 3 (PS3) Console
MH1160 Whirlpool Microwave Stopped Heating
Are you getting 110VAC on the primary leads of the high voltage transformer when you press "Start" to begin cooking?
If not, yhen it may simply be a bad cook relay (I do board repair) or a bad bottom or inside top door switch. See http://www.microwavecontrol.com/doorsw.htm
E-mail me via my site for more free help.
William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 21, 2017 | Whirlpool MH1160XSS Stainless Steel 950...
When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
Aug 04, 2009 | ASUS Eee PC 900 Notebook
Computer will not turn on
The only way you can see if it the motherboard or the card is to try them in different machines I.Eputting the card in a buddys pc and try another AGP card on your board. I am glad that we were able to figure out the problem
Mar 24, 2009 | Intel Motherboard
I have no sound on incoming calls unless the phone is on speaker.
Try putting the phone on silent mode and then back to ringer.
David
www.cellunlock.net
Feb 03, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer won't spin
Maybe when you were behind the machine, you did not refit the outlet pipe at the correct height; this is a height approx. 3 feet from the ground or more. Your pump pumps the water OVER this height.
You said it does not spin; you shd check out your outlet filter and clean it. If this is clogged the machine will not spin. All the best!
Nov 06, 2007 | Frigidaire GLTF1040A Front Load Washer
ASUS Motherboard Striker II Formula  Logo
121 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
