Question about Nokia 6233 Cellular Phone
Replaced lcd screen but phone won't turn on.
I got a new screen for my phone today. I replaced the screen but now the phone won't turn on. I have tried taking it apart and making sure everything is plugged in properly but nothing. The battery was full charged as well. does anyone have any ideas what I can do. Thank you
  • 244 Answers
Re: replaced lcd screen but phone won't turn on.
Hi deadbone69,
Is this your first replacing screen in your phone? If that so, it is possible you dislocated the internal connection on your phone that unable you to turn on your phone.
The best advice is to look for a phone technician that can work your phone model.
Hope this is will be a helpful to you.
Best regards,
Posted on Oct 24, 2007
0 characters
3 Points
I dropped my phone and the screen won't come back on, whats the problem?
your lcd is more than likely cracked or damaged your probably gonna need to have the screen LCD replaced
May 11, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
My iphone 3g 8gb seems frozen, on my main screen it says slide to unlock, well it won't slide to unlock, ive turned it on and off again and done the reset thing but no joy at all, does this mean my...
try the new update that just came out today , sync your phone in itunes and then install the new update on the ios software . hopefully this works
May 05, 2011 | Apple Cell Phones
I have a iphone 3gs just purchased a couple of days back. Its brand new, have never droped the phone nor any signs of scratches or wear. Today morning I saw the screen was fluctuating with lines appearing...
My guess would probably be that the lcd in the phone was damaged maybe from temperature changes from where it was assembled to the time that you are holding the phone. You can fix this problem (if it is just that the LCD is damaged) by going here( ). you will need a very tiny Philips screwdriver and a suction cup that will fit on the glass of the phone. you remove the screws in the bottom of the phone by the dock connector and then take the suction cup to the bottom half of the screen and pull straight up and the digitizer and bezel should pull right up and then from there it should be pretty self explanatory to replace the lcd
Oct 09, 2010 | Apple iPhone 3G
Nokia n70 is showing white blank screen
possible the firmwar is damage or sum ics have burn because of a power spike, or brownage while it was on charge, take it to a repair shop to be checked
Oct 08, 2009 | Nokia N70 Cellular Phone
Dropped phone screen stopped working
If the screen on your 5310 is deador the backlight is not working, you can buy a replacement 5310 LCD andreplace it yourself. A new Nokia 5310 display Screen costs about 20 dollars fromebay. I wrote a detailed guide to help you put in the new Nokia 5310 screen. Check it out at the following link:
Nokia 5310 LCD Screen Replacement
Hope that helps
May 13, 2009 | Nokia 5310 Cellular Phone
Blank screen
40something - you will need to take the phone and have the flexcable replaced or lcd
sandhy - THe lcd needs to be replaced
GUEST - replaced the LCd or flexcable on the phone
Aug 28, 2008 | Samsung SGH-E900 Cellular Phone
Outside screen is blue
have the lcd replaced on both phones.
Mar 08, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Flip open the phone and look for (4) rubber plugs at each corner of the inner LCD screen.
Using a very small flat-blade screwdriver, pry these rubber plugs out and you'll see the screws beneath them.
Remove the screw and you should then be able to take the flip part apart. Be sure to put the plugs and screws in a secure place so that you don't lose them.
Please let me know if I can be of further assistance to you.
- Jim
Feb 08, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Nokia 6233 Cellular Phone Logo
121 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
