Question about Canon PowerShot S400 / IXUS 400 Digital Camera
No image memory card error message Have replaced batteries and put in and formatted new card.
  • Canon Master
  • 4,738 Answers
My cam says "memory card
If the camera displays Memory card error or No Memory Card when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. If this is the case, you may wish to Format the memory card in the camera using the Setup Menu option [Format] as shown below. Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data. This can also be caused when images shot with another camera are stored on the memory card.
If after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service. If the card appears to be defective you may wish to contact the memory card manufacturer.
Thank you!!
Sep 04, 2011 | Canon PowerShot SX210 IS Digital Camera
Tip
How To Fix You Camera's "Card Error" or "Card Not Initialized" Message
When you recieve a "Card Error" or "Card Not Initialized" message, this indicates that your memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most consumers will use the "delete all" feature and continue to take pictures. By doing this, the file format of the card may become unstable.<br /><br />We recommend formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted, the images will not be recoverable.<br /> <br /> If this doesn't fix the Card Error, try replacing your batteries with a new, fresh pair of batteries. Also, if you haven't tried already, replace the memory card with a known working card and see if this fixes your error.
on Feb 14, 2011 | Cameras
My camera is giving me a "no memory card" sign, but the card is inserted correctly. I have taken it out, cleaned it, and put it back, replaced the batteries, and everything. However, to no avail....
If the camera displays Memory card error, No Memory Card, or takes an abnormally long time to write an image to the memory card, when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. For SD card, make sure that the card lock switch is in the correct position and not stuck in-between.Try formating the memory card ,if after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Mar 19, 2011 | Canon PowerShot S51S Digital Camera
I have a finepix S602Z and when i turn it on it comes up as card error this happens on different cards any ideas on how to correct this please
I suggest you take the batteries out and wait two minutes and reinsert them. Making sure that they are inserted correctly. If this doesn't work, try replacing the batteries with new ones.
If you formatted the memory card using your computer, or deleted images using your computer, you now need to Format the card with the CAMERA. One of the camera menus will have a Format command.
This is what FujiFilmUSA.com has to say about the Card Error:
Feb 14, 2011 | Fuji FinePix S602 Zoom Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
Apr 12, 2010 | Samsung S630 Digital Camera
I have a Kodak easyshare LS443 and when I put in a new picture memory card (bought two of them already), after it says 'format memory card' and I do, it just keeps saying 'reading memory card' and nothing...
Make sure that the memory card you used is compatible w/ your camera. If same issue persists after using the compatible card, camera is unable to detect the memory card. Card compartment is defective. call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 25, 2009 | Kodak EasyShare C875 Digital Camera
I have a Nikon D50 with an error message "CHA"
This error indicates the following:
This card cannot be used (CHR) blinks.
Problem(s)
Error accessing memory card
Unable to create a new folder (on card)
Card has not been formatted for use on D70
Try another card
Format the card using your D70 (all images will be erased)
Check the card for visible damage or poor contacts.
You may have inserted a memory card that was been used in a different camera or the formatting process did not complete successfully.
I hope this helps.
Jan 30, 2009 | Nikon D70s Digital Camera
Nokia 6630.Changing Memory problem and phone memory low errors
try again format ur phone,but b4 that,put out ur memory card.after format ur phone,format ur memory card on pc by using card reader.after both format complete,put ur memory in phone,format ur memory card again in phone.ok.try this 1st.send feedback to me.
Jun 21, 2008 | Nokia 6630 Cellular Phone
Error 10 message
The error 10 message is trying to tell you that the new memory card you have tried to put in is not compatable with your camera. AS you have already tried turning it off/on, replacing batteries etc, you can try taking all cards out, and attempt to get it to fuction correctly with original cmaera memory. After taking out all cards, and with a fully new set of batteries in, use your cameras menu to format the camera memory. Now try and take photos with just normal memory. Is it working? If it does, and error is gone, put in old memory card and reformat it. Does camera pick it up and recognise it. Can you now use it. The new card you tried to install may have been an incompatable brand. Check your manual for approved brands or your local dealer. The card could also be faulty.
Aug 08, 2007 | Nikon Coolpix 4600 Digital Camera
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
146 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
