Question about Sony VAIO Notebook
Computer graphics are shimmying, then shut down. I have a problem with NVIDIA and one message said that the BIOS would not support the latest MS updates. What can I do?
Nvidia quadro fx 3450 the computer starts normally, but no BIOS display, nothing.
before installing latest drivers, uninstall the old one, seems to be a bug with nvidia card drivers
Mar 07, 2014 | Nvidia Quadro FX 3450 Graphics adapter-256...
Quickbooks conflict with nvidia
If you installed the latest NVIDIA drivers, did you also try installing a different PDF printer driver? I would suggest try installing a different PDF printer driver like PDF995 or Foxit Reader. Post back how it works out.
Jan 03, 2014 | Nvidia Computers & Internet
I did't found galaxy 9400gt 1gb ddr2 bios update anywere so can u plz help me how can i update my graphic card bios
The bios should update when you install the latest NVidia drivers, which are located here. Have a great day
Jun 22, 2011 | Nvidia Microsystems GeForce 9400 GT, PCI...
I recently bought a Nvidia GeForce 6200 256Mb AGP card to replace a 5200 card so my daughter can run her school assistance programs. its my old computer and I never had any problems with the old card...
Sounds like a Driver Conflict.
Still have the old 5200 drivers in there?
Did you install the drivers for the 6200, BEFORE you physically put the graphics card in? (Not shouting)
Let's say you did remove the 5200 drivers, before you installed the 6200 graphics card.
BUT,
If you physically install the 6200 graphics card, BEFORE you have installed the drivers, Windows 'sees' a new device, and hurries up to match one of it's generic drivers.
(Windows has thousands of drivers!)
Now you come along, and install THE drivers for the 6200. Windows has a drivers conflict.
Windows: "Which drivers do I use? These, or THESE?"
Makes for a garbled graphics display as you've described.
If the above is true, start over.
Go to Add/Remove Programs, and Remove the Nvidia software. All of it that has Nvidia next to it.
(THIS, is provided of course, that the computer HAS Integrated Graphics, and does not just use a graphics card. You will be plugging the monitor, into the VGA port in the I/O area, on the back of the computer temporarily, if this is true, and this computer has Integrated Graphics)
(Start>Control Panel>Add/Remove Programs) If there is more than one Nvidia program listed, Do No restart the computer each time you remove one. Do Not restart. Read on)
After all Nvidia software has been removed, close Add/Remove Programs, close Control Panel, and return to the desktop screen.
Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Unplug the computer from power.
Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. (Count, 1001,..1002,..1003,..1004,..1005) Let go of the Power On button. Do this procedure Two more times.
What you are doing is clearing any CMOS Error Codes, and resetting BIOS back to the factory default settings.
Open the case. TOUCH the metal frame of the case to relieve your body of Static electricity. Remove the 6200 card. Plug the monitor into the back of the computer into the VGA port. Leave the case open, you'll be going back in there.
Plug the computer into power. WAIT 1 minute, then turn it on. After Windows has fully loaded, install the GeForce 6200 drivers from that CD disk. Do Not restart.
Shut down normally.
Unplug from power. Touch that metal frame again. Install the GeForce 6200 card. Close the case. Plug the monitor into the GeForce 6200. (You did plug the monitor into the 6200 the first time, right, and not the VGA port?)
Plug the computer back into power. WAIT 1 minute. Turn the computer on. Go to Start>Nvidia>Nvidia control panel, and set the settings.
Aug 15, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Can i put nVIDIA geforce 8600 on my p5sd2-vm
Yes, your Asus motherboard will support the Nvidia GeForce 8600 PCI-Express graphics card.
However one thing you should consider. The 8600 card is SLI compatible but the motherboard only has one PCI-E x16 slot.
You will also need to make some changes in your bios.
In order to help you configure your system for a PCI-E graphics follow these steps.
1. Uninstall your current display driver software through windows control panel. Windows may ask you to restart your system, do not restart. Shut windows down which will shut off the system.
2. Unplug the power cable from the system & open your case.
3. Install your 8600 card. (Double check it is installed correctly & if needed has the extra power cord connected to the card.
4. Re-connect the power cord.
5. During boot up enter the bios by pressing the Delete key every couple seconds.
6. Once in the bios click the Advanced tab, see top of page 2-19 in your manual.
7. Than open Onboard Device Configuration
Open North Bridge Configuration, see page 2-22
Change Primary Graphics Adapter to [PCI-E]
Change Internal VGA to [Disable]
Change Share Memory Size to [Disable]
8. Save Bios changes & exit. Your system will auto restart.
Once windows has finished loading install the 8600 driver software & directX 10.0. You can also go to nVidia & download the latest software driver @
http://www.nvidia.com/Download/index.aspx?lang=en-us
Thanks for using FixYa!
Mike
Jun 19, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Geforce 8500 GT Causes "Snowy" screen
You have Vista 64 bit right? I looked and the newest nvidia driver is 182.08 located here:
http://www.nvidia.com/object/winvista_x64_182.08_whql.html
1. Download this driver.
2. Go to the Control Panel, Programs and uninstall the current nvidia driver.
3. Shut down computer.
4. Remove video card and re-install it.
5. Start computer and install new nvidia driver.
Mar 11, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Display problem in MS office graphics on Asus AMD board
maybe is the drivers of the graphic card, is it updated?
if not just go to the nvidia site and get the latest drivers :)
Jan 03, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
AMD Computer Reviews - Phenom 9850 Quad Core Processor - HD985ZXAGHBOX with biostar n750 motherboard sli ready nvidia 9500gt graphics card after putting vista on worked great, until i installed the...
reboot the computer and press F8, start in safe mode and unistall the graphics drivers using "device manager" reboot the pc and do a microsoft uptade to install the drivers for you
hope this helps
regards
Nov 19, 2008 | AMD Computers & Internet
SAVING SETTINGS
When you hit Save or Apply in the Control Panel, the driver remembers the settings. You did that right.
The problem might be when the computer restarts, that the graphics card doesn't correctly check for the SVIDEO output, OR your monitor is missing a resistor (some Sony and Panasonic) on the Chroma output that tells the video BIOS that there is actually something attached (DC-coupled). The latest NVIDIA drivers can detect AC-coupled monitors on the latest GPUs, but since the VBIOS sets the environment, the driver may not check again.
It is possible that uninstalling the video driver and installing a newer one might solve the problem
Aug 04, 2008 | Nvidia GeForce 7200 Graphic Card
Game graphical error
Wierd, I had this problem once, updating my driver simply fixed it. Do this: 1) Remove all nvidia products and drivers from your computer. 2) Reboot computer of course. 3) Go to Nvidi'as website and download the correct latest driver for your graphics card. 4) Reboot again. 5) Go test the game.
Feb 24, 2007 | XFX GeForce 6200 Graphic Card
Sony VAIO Notebook Logo
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
