Question about Comdial Unisyn 1122S Corded Phone
The speaker light stays on at all times. - Comdial Unisyn 1122S Corded Phone
Red protection light stays on all time....
try disconnecting one at a time each speaker till the red turns to green. One of your speakers may be bad. Amp is just telling you that its clipping and overheating due to the change in ohms of a shorted or bad speaker. Its also possible the amp is on its last leg due to heat. Heat breaks down electronics part and eventually get worse.
Apr 05, 2010 | Car Audio & Video
The DDT light on one channel stays on,but I can't find a reason why? What can I do?
Disconnect the speaker wiring and speaker on the bad channel. Turn the level control(s) all the way counterclockwise and turn the amp on. If your DDT (limiting) light remains lit, it's time for a visit to your nearest certified Peavey service center....G.
Feb 05, 2010 | Peavey Pv 2600 Power Amplifier
On/standby Red light blinking can't turn on system
It's in protection. Disconnect all your speaker wires at the receiver then power it up. If it stays on, the receiver is ok and you need to check all wires and speakers for shorts. The easiest way is to reconnect one speaker at a time and test power until it shuts down, then disconnect the speaker wire at the speaker and test again. If it stays on, meter the speaker for shorts or bad voice coil. if it still shuts off, check your wire or replace. If the receiver's power still flashes with all speakers disconnected, it needs service or replaced. Before reconnecting your receiver after repair or replacement, check all wires and speakers 90% of the time, that's the cause. Hope this helps. If you still need help, post a comment and I can help you troubleshoot further.
Oct 17, 2009 | Denon AVR-2807 Receiver
Red Light
that means you probably have a shorted speaker wire, a bad speaker or the amp itself is bad, try disconnecting the speakers one at a time and see if it turns on or not. if the red light stays on with no speakers hooked up it means the amp is bad
May 30, 2009 | Kenwood KAC-7252 Car Audio Amplifier
Standby light stays red and will not turn unit on.
Try to reset the macroprocessor. Unplug the unit from AC, hold both buttons SPEAKER A and SPEAKER B and plug the cord in outlet. After display flashes several times release the buttons. No result? - repair shop.
Apr 05, 2009 | Denon AVR-1906 Receiver
Transmitter light does not come on
Just switch the polarity on your plug from positive to negative...it will work!
Dec 31, 2008 | RCA WSP155 Main / Stereo Speaker
Sonamp 260 cuts out
Normally this denotes a protect condition. Remove the speaker wires from the back of the amp and see if the green light stays on. If this fixes the problem, then there is a short circuit in your wires, speaker level volume control or speakers. The amp sees the short and goes into protect. After a couple seconds it closes the connection again and if the short is still present it goes back into protect.
Aug 03, 2008 | Sonance Sonamp 260 MKII 2-Channel...
Comdial Unisyn 1122S Corded Phone Logo
44 people viewed this question
Top Comdial Lands Phones Experts
george  peters
george peters
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
