Question about Nintendo DS Lite Console
My nintendo ds keeps flashing white when i turn it on then go of
My nintendo ds flashes white on the bottom then brakes
  • 32 Answers
By brake do you mean turn off?
If you do then charge it
Posted on Sep 03, 2009
  • 26 Answers
Your bottom screen needs to be replaced or the whole system all together needs to be replaced.
Posted on Aug 18, 2009
    Problem Solver:
  • 7 Answers
The fact the bottom screen flashes and the top doesn't indicates that the top screen needs replaced! Although do not attempt this as a D.I.Y project as its more complex than some think. And the 2 speakers also need to be desoldered and then resoldered to the ribbon on the new top screen and this requires soldering skills. If you stay in the glasgow area you welcome to contact me for repairs.
Posted on Jul 13, 2009
How do you get rid of the white screen of death on a ds
What is the screen doing? Does it just flash for a second then turn off? Or does it stay like that until turned off?
It could be the screen itself or the ribbon connecting it to the motherboard. Open your DS and see if the ribbon is messed up in any way.
It could be the motherboard, too, which could mean you need to replace it.
If it flashes for a second then turns off, it means that the screen that didn't flash (be it top or bottom) is needing repair.
Nov 09, 2013 | Nintendo DS Lite
I turn on my ds green light comes on bottom screen flashes then turns off
    • 1 Turn off the Nintendo DS, and place it on the charger. Leave the device for 45 minutes to allow it to gain a full charge, and then power it back on. Weak Nintendo ds lite batteries may cause screen flicker.
    • 2 Turn off the DS, and remove all game cartridges. Turn the system back on to launch the main menu.
    • 3 Click the small sun icon to open the brightness menu. Adjust the brightness level using your stylus. Turn it up to max to improve back lighting.
    • 4 Check that the Nintendo DS is open and in the locked position. It must be open to its default position to operate properly.
Apr 15, 2012 | Nintendo DS Console
My son's DS lite stopped working while he was playing. Tried charging...no good. Bought new battery...no good. When turning on the charge light turns green then the bottom screen flashes white (like it...
Hello there! First of all let me tell you that your nintendo ds can be repaired and it is not trash... what you need is to get the bottom screen to be repaired ....you can do it sending it to the nintendo repair shop or by doing it yourself by following this youtube guide http://www.youtube.com/user/nintendorepair.
Sep 21, 2011 | Nintendo DS Lite Console
Screen goes white on power on and then shuts down power
This is basically due to a faulty screen. Depending on which screen flashes white when you first turn the DS on, this tells you which screen is faulty. If the bottom screen flashes then it is the top screen that is faulty. If the top screen flashes then it is the bottom screen that is faulty. Screens are fairly easy to fit although the top screen is the harder out of the two, you can buy them off of ebay for around £10 and if you google DS screen replacement there are some good guides out there showing you how to do it.
Hope this helps
Jan 29, 2011 | Nintendo DS Lite Console
On my ds the light comes on for two seconds then a white screen appears then it goes off what should i do
Depending on which screen flashes, one of them has died. If the bottom screen flashes then the top screen needs replacing, if the top screen flashes then the bottom screen needs replacing, the easier of the 2.
Hope this helps
Jul 23, 2010 | Nintendo DS Console
Ds lite screen flash white tehm off
The screen that does NOT flash will need replacing.
It may look fine and dandy but there is still an issue.
The reason for the flash is that when switched on the DS lite performs a qucik check of the screens, if there is an issue the unit will switch itself off again.
My answer is, judging that you have said you have taken it apart to have a look that you are willing to repair it yourself.
Have a look on ebay for the relevant screen (plenty of people on ebay stock them) and then replace the screen that does NOT flash.
This should solve your issue.
If you need a guide to replace the respective screen click on my name to access my profile and at the bottom of the page you will find my guides.
Hope this helps,
Regards,
SOD69
May 14, 2010 | Nintendo DS Lite Console
NDS LITE WILL NOT TURN ON
send it to the nintendo people
Jun 21, 2009 | Nintendo DS Lite Console
Nintendo DS Lite won't turn on
My kids did the same thing. What I did to get it to work was to push back on the top and hold it turn it on. If it comes on then turns off after you let it go get 2 rubber bands and put the 1st. one on the top left down to the bottom right. The 2nd. one goes from the top right right to the bottom left. Then keep turning it on while moving the top to find the sweet spot.
Jun 03, 2008 | Nintendo DS Lite Console
Nintendo ds problems
Not meaning to sound patronising, but have you powered it up again?? My daughter loses battery power quickly and needs to charge it often!
Mar 11, 2008 | Nintendo DS Lite Console
Won't power up-flash of light on bottom screen then nothing
if yr DS is less than one year old, call nintendo and ask for an advanced replacement.... they are good about it and will explain the whole process to you....the number is 1.800.255.3700.... i think it is option three for DS problems, then zero, and the will set it up.... ive had it done like three times....
Nov 27, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
618 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
