Question about Kenmore 25852 Top Load Washer
Won't spin or agatate - Kenmore 25852 Top Load Washer
    Genius:
  • 1,122 Answers
Bad motor coupler,-mike
Posted on Jun 03, 2009
Model #110.49962600 water fills agates will not spin
And the code is!? Gee I hate when that happens! OK look at these:
F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
• F3--Pump problem.
o 1. Check pump trap and clean.
I go with the last one..Common, then the pump is bad then the valve. But You didn't tell Us!
Jan 16, 2014 | Kenmore Elite 45986 Front Load Washer
Spin cycle does not always remove enough water, so...
Take the agatator out and check the drainage it will be bloked clean as required. Hope this helps
May 17, 2010 | Washing Machines
AGITATOR NOT SPINNING WHEN THERE IS A LOAD IN MACHINE. IT SPINS WHEN NO LOAD IN MACHINE. (GE TOP LOADER)
Check to see if the nut on top is loose if it is tighten it up by holding the agatator with one hand then screw the cap back down, if it is still not working you will need to see if the agatator is stripped if it is you will have to buy a new agatator and you can find them at this web site. www.appliancepros.com
Nov 13, 2009 | GE WBSR3140DW Top Load Washer
Agitator problem
Check to see if any thing is under the agitator. If not then maybe the bearings going out or other part of machine . Besure the cap is tighten so agatator don't come off. Check for ware on agatator top to the tighting nut.
Jun 02, 2009 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
Wont fill and agatate
sounds like the water valve check for supply taps make sure there on test solenoid's on valve for ohms Resistance or closed circuitif open replace water valve
Aug 29, 2008 | Kenmore 98702 Stacked Washer/Dryer
Maytag Top Load Washer - clanking noise when spinning
no spin cycle or agatator movement , fill cycle and pump cycle works
May 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 4 years old has prob
You may not have the coupling seated properly. However, if the unit is agitating and spinning at the same time, you may have a more serious transmission problem.
Kenmore 25852 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
