Question about Maxtor Hard Drive
AutoPlay Problem On Hard disk drives
When I right click on my drives (d , e , f , ...) at top there is a autoplay which don't fix either with changing windows
  • 244 Answers
Hi mamali,
You are affected with a spyware that fault your current drives in opening normally. If you can still access and open the drive please do the following.
1.) goto tools> folder option on the windows explorer.
2.) the click the View Tab.
3.) Select hidden files and folders.
4.) Unchecked Hide extentions for known file types.
5.) Unchecked Hide Operating protected system files.
6.) Click Apply to all folders button then press OK button.
Now, try to open the drive by exploring it and delete all the hidden file which you observed you didn't seen it before the changes was made.
Restart your PC, to take effect.
Hope this will be the best solution for you.
Best regards,
Posted on Oct 24, 2007
Optical drive D: repair in windows 8.1
Sounds like Autoplay is not configured. You can see how to change your Autoplay settings on Microsoft's web site here: Autoplay is a strange duck, doesn't always work regardless of settings. You can also open 'computer', which in Windows 81 shows as your User Name, not 'Computer' or 'My Computer' like older versions, then right-click Drive: D, and click 'Play with VLC Media Player', which is the best player I believe - I've used it for years.
Feb 11, 2014 | Toshiba Satellite S955-S5376 15.6-Inch...
I hav e Zoo Empire for Scholastic on disc, when I try to load it the computer does nothing. Why will it not autplay?
It seems that you have Autoplay disabled on your computer, OR the disk is damaged OR the disk don't have "autoplay.inf" file on his root.
The best solution is to put your disk into the drive and try to access it via FileManager: Double Left-Click on MyComputer icon on desktop -> locate the CD drive and make Right-Click on the CD icon followed by the "Explore" option selection. A new window appears which shows the CD content.
Locate a file called "setup.exe" or "install.exe" or similar, and make double left-click on it! That's it!
Jun 27, 2011 | Computers & Internet
Hi there, I formatted the goflex because the seagate software was acting up in the vista 64x machine I'm using and was forcing me to use the seagate software without allowing for me to drag/drop and...
  1. In My Computer, right click on the drive you want to AutoPlay (it will not display if it is not plugged into your computer) and select AutoPlay.
  2. Choose the best option for you and press OK. Remember, there are several options available, including playing Media Files, copying pictures to your drive or if you have a program installed that can AutoPlay (autorun) such as Menu from If you need to reset your options, just follow these instructions again!
And that's it!
Jun 06, 2011 | Seagate FreeAgent GoFlex Desk - 1 TB...
My dell studio 1535 will not open a cd, when I insert the cd nothing happens. I just had a new hard drive installed..
If the CD-ROM will boot from a recovery CD, then this would indicate a Windows software problem instead of a CD-ROM issue. It can usually be attributed to a corrupt driver. To reinstall the drivers:
1. Go to Start>> Right click My Computer>> Properties>> Hardware>> Device Manager.
2. Expand DVD/CD-ROM Drives line item.
3. Right click on the items below and select Uninstall drive on the resulting menu.
4. Re-boot the system and Windows will automatically detect the CD-ROM drive and re-install the drivers for you.
Try a different media - some brands will just not work correctly with a given CD-ROM drive. Watch out for compatibility problems with Maxell, Memorex and Macromedia CDs.
Check for unusual noises, maybe a ticking type noise. This could indicate a cracked disk. Or, the media may not be seated correctly on the spindle.
Is the access light on?
Is the CD Clean?
Check error messages in Event Viewer. Here's how:
Go to Start>> Settings>> Control Panel>> Administrative Tools>> Computer Management (or Event Viewer)
Check your manufacturer's web site for software updates and drive updates. Check for QSI firmware updates.
For DVD - Are you trying to write to a DVD that is READ ONLY?
If all has failed, you may be faced with performing a complete Operating System Recovery or Repair (preferred).
If nothing above has worked for you, then you may need to take the drive in to a service facility for repair or replace the drive.
Jan 01, 2010 | Dell Studio 1535 Notebook
I have i-rocks 3.5 sata hdd hard drive external. I can't find any paperwork on this device. How do I change settings. It's starts autoplay each time I start computer and files are often duplicated, wasting...
Right click on Start, left click on Explore. On the left panel in Explorer find your External hdd. Highlight the drive, right click and open properties.
You will find a tab that says Autoplay Select this tab and choose what you want this drive to do.
Jul 19, 2009 | Computers & Internet
Another way to disable autoplay in XP (don't know if this works in other versions of Windows) is to click Start -> Run -> type "msconfig" -> click the Services tab -> and uncheck the selection called "Shell Hardware Detection". This will disable autoplay for not only all of your CD-ROM drives, but any other form of removable media (ie memory cards from your digital camera).
May 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I have a problem with my 512 mb PQI fash drive
Hi. How do you open a flash drive anyway? Cause me... I'll just right click the drive then click the "Explore" menu and thats the way to avoid virus menu like the Autoplay(once you double-click the drive, it wont open 'cause it has an extra Autoplay menu}. By the way, does your PC virus-free?Try to check the drive by right-clicking the drive. If you see two Autoplay menus and the other Autoplay is highlighted or the font is thick, your PC surely has a virus. You must remove it first.
Or try to go to do this:
Contol Panel/Administrative Tools/Computer Management/Disk Management and look for the drive. Right-click it and click the Open or Explore menu.
I hope I help you with this kind of suggestion.
Jan 23, 2009 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Installling printer
Did the software cd not start? If not, go start, click on my computer> right click on your cd drive>click on explore. There should be a file autoplay, setup or install. They all get you to the same place. Start with autoplay. Double click. Your software should start. If there's no autoplay just work your way down the list. If this solved your problem please rate this as fixed. If this was not your problem or need further help just add a comment and I'll be happy to help you further. Thanks.
Apr 10, 2008 | Lexmark Z600 InkJet Printer
Dvd/cd rom drives
i cnt run my dvd rom drive but only cd.disk
Oct 15, 2007 | ASUS 52x (CD-S520) QUIE TRACK BEIGE RETAIL...
Maxtor Hard Drive Logo
59 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
