Question about Infinity Reference 1211a Car Audio Amplifier
Infinity 1211a @ 2 Ohms
Okay, i have a infinity 1211a amp. Its rated 1,300 RMS watts @ 2 Ohms. I'm thinking about powering a pair of Infinity Perfect 12.1 SVC in 2 Ohms load. Will this give 1,300 RMS watts to each woofer, or to the pair of woofer meaning each sub will share half the 1,300 watts..??..
Thanks,
  • 1 more comment
  • monkey_flea Jun 03, 2009
    Thanks etirbynnor for your solution, very helpful..Now I know not to overpower the subs..Lastly, how many watts will be going to each sub if I wired them in 8ohm load on w/ the Infinity 1211a..??.
    Thanks
    Thanks etirbynnor for your solution, very helpful..Now I know not to overpower the subs..Lastly, how many watts will be going to each sub if I wired them in 8ohm load on w/ the Infinity 1211a..??. Thanks
  • Israel Adame
    Israel Adame May 11, 2010
    Does the amp say 1300 RMS watts @ 2 ohms per channel or total power?
  • 655 Answers
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Posted on Jun 03, 2009
  • Ronny Brite
    Ronny Brite Jun 03, 2009
    Hello again monkey_flea,
    While Infinity does not list an actual rated power into 8ohms, it produces 1300 watts at 2ohms and 854 watts at 4ohms, so it appears that the power would be reduced by about 34% into an 8ohm impedance. Each sub would be getting approximately 300 watts.
  • 22 Answers
That amp is a true RMS power and it is a type D mono amp, so it will put 1300 watts rms in each speakers, mono amp never share.
Posted on Aug 11, 2009
I have a Miata with two speakers in each headrest. I have new amp to wire into speakers I have bought for replacement. My 4 Infinity speakers are 2 Ohm. My amp is rated: Channels 4-Channel RMS Power...
There is a way to do this, but it is awkward and is not recommended. Depending on the impedence of the door speakers and how many there are. I am assuming from your posting that you have a 2 channel amp. If you wire the two speakers for each seat in series (creating a 4ohm load), then wiring both seats in parallel (putting the load to 2ohms), these could theoretically be wired to one channel. BUT, this will not give you balance left and right. Also, if the impedence is different, you run the risk of damaging the amp.
Jul 30, 2011 | Car Audio & Video
Can you use a bazooka ba1150 to power up an infinity 1230w sub? not a techie just happened to have these two items and was wondering if i can use them together. thanks.
This is an 150 RMS amp, but the ratings say it'll push 2 10's.
You probably won't get much out of that amp with a 1230 watt subwoofer.
The subwoofer you are wanting to run is 300 RMS, so you'll get half the power you could be pulling. But it would do okay I guess. Nothing like what you could get with a different amp though. You need like a 1000 watt amp to get the most out of your sub. But "YES" you can use them together.
Aug 01, 2010 | Bazooka BA1150 150 Watt Monoblock...
I installed a sony 600watt amp and it works but old rockford fosgate 200 hit harder how do i make my amp louder and evenly spread throughout my car
Hello jmanbutt99,
The old Rockford-Fosgate was probably producing the rated power. The Sony is most likely overrated. But, it's supposed to be stable on each individual channel down to 2 ohms and will deliver 65 watts RMS into that load. So to get the most from it, your best bet would be a pair of 4 ohm speakers paralleled to each channel. A relatively efficient speaker like the Kicker 07DS600's shown here should provide pretty good sound.
http://www.crutchfield.com/p_20607DS60/Kicker-07DS600.html?tp=105
These will work with as little as 6 watts RMS and can handle up to 50 watts RMS so the Sony should power them really well. They're 4 ohm so a pair in parallel will present a 2 ohm load.
Hope this helps
Oct 30, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
I just need to know the best way to hook my amp and subs together. i like a lot of bass. i just bought the subs and yhey dont really sound any diffrent. should i get a new amp.
Hello hembreegerry,
If you like a lot of bass, you definitely need to consider another amp. The SP2X-300 is only rated at 170 watts RMS into 4 ohms mono. That would barely be enough to power one small sub. You do not specify what brand and model your subs are, their impedance, or their power handling capacity. But for any subs, your best power solution is to add together the individual RMS power handling capacity and select a monoblock amp that provides close to the maximum at the impedance they will be wired to present. For example, if your subs are 4 ohms and have a maximum RMS of 250 watts, you would want an amp that outputs abour 500 watts into 2 ohms (2 4 ohm subs wired in parallel = 2 ohm load). An ideal amp in that example would be the Alpine MRP-M500 which outputs 500 watts RMS into 2 ohms.
Hope this helps.
Sep 10, 2009 | Power Acoustik Sapphire SP2X-300 Car Audio...
Mtx audio 4252 amplifier
Hello freshman_fox,
63 watts X 2 @ 4-ohms.
125 watts X 2 @ 2-ohms
250 watts X 1 @ 4-ohms bridged
Since no power rating is given @ 2-ohms in bridged mode, it means that the amp is only stable to 4-ohms.
The manual does not specify a peak power, but since RMS is about 70.7 of peak, that makes it 353.5 watts.
You can download the manual from here. Hope this helps.
Jul 10, 2009 | Car Audio & Video
I don't know how many watts is this amp
ECLIPSE makes a 32440
If this is the amplifier you are looking for specs on...
4 x 85W @ 4 ohms (13.8V - 0.1% THD)
4 x 120W @ 2 ohms (13.8V - 0.1% THD)
2 x 240W @ 4 ohms bridge (13.8V)
Thanks for using FixYa -a FixYa rating is appreciated for taking the time to answer your Question.
Mar 28, 2009 | MTX Thunder 1501D Car Audio Amplifier
Is it enough to power to 12 volge=ahagen 12oowatss dual 4 ohms
your Volfenhag 12" subs are rated at 1200 watts they are only 600 watts rms and the Rockford punch p4004 is only 200 watts rms so the answer is yes it will work but if you get a amplifier that pushes out 500 - 600 watts rms you will love the sound from subs
there is nothing wrong with the Rockford amp it just wont pound out the bass as hard but the good news is you will never blow the subs with it
when buying amps or subs make sure to look at rms rating that is the true power they actually have ie. (sub box says 1200 watt you think powerful but if you divide it in 1/2 you actually get 600 watts rms) don't get me wrong that's a nice rating. for a sub but you will want to match that number with the amps rms rating or lower. The RMS is what makes the car pound the higher the RMS the better
hope this helps
Mar 05, 2009 | Rockford Fosgate Punch P4004 Car Audio...
Support Question about RMS
you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
if you have any questions email me at thadoggma420@hotmail.com
Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Amp getting really hot
well it is getting hot due to the amp drawing and pushing alot of current. try getting lower gage wiring for power to the amp and lower gage speaker wire.
Apr 20, 2008 | Power Acoustik PS2-1200 Car Audio...
Infinity Reference 1211a Car Audio Amplifier Logo
273 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
