Question about E-Machines eMachines T3830 PC Desktop
Low memory My pc operating on 192 MB of RAM. How much do I need and where do I purchase it. And how do I install it?
  • Carlos Soto
    Carlos Soto May 11, 2010
    Can you provide more information on your system? I am guessing you are using DDR memory, but that's a guess.Can you provide specific model numbers to the system?
    Sergeant:
  • 310 Answers
Hi, first thing you need to do is remove the side panel of the pc and have a look inside until u find the other sticks of memory, once u do you will get the type of memory like ddr 1, ddr 2 etc has to be the same kind, you will be able to buy it from www.ebuyer.com cost about £12 - £35 for a 1 gb, depending kind of memory etc.
you will find step by step instructions here,
http://www.onlinepcstudy.com/documents/install_memory.html
thanks
John
Posted on Jun 03, 2009
My system has a ddr 256 MB but it shows 192 mb only. what is the reason and solution plz
Your graphics card is sharing your system memory.
This means that you physically have 256 MB of Ram in you laptop, but the operating system can only use 192 MB of Ram because 64MB of Ram is dedicated to your on-board graphics.
Hope this answers your question!
Please remember to let me know if this information was useful!
Kind Regards
Dec 06, 2010 | Intel Motherboard
My everex computer has 448 mb of ram i would like
Actually your computer does have 512 RAM. The 64 MB discrepancy is what the graphics memory uses. 64 + 448 = 512, get it?
If you want it to show full 512 MB, you need to install a separate video card. Refer to your PC's manual and see if it has a separate AGP or PCI-E slot.
If it has then you can choose from the many available in the market.
You can choose between having a low end low cost or a high end one designed for gaming. Just choose what suits you best and remember that a higher power card requires proper cooling and higher wattage PSU (power supply).
Note that no matter how much RAM is installed, some portion of it will be used for graphical operations.
Oct 03, 2010 | Everex eXplora RS2800 PC Desktop
Can it support expanded ram - what is the upper limit on ram capacity
below are the specs for your laptop,
Standard Memory 64 MB (non-removable) Maximum Memory 192 MB Memory Expansion 1 socket Memory Comments PC100 SDRAM SODIMMs CPU Type 650MHz Intel Mobile Pentium III Model Comments 100MHZ FSB
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
buy more ram here: http://www.memorystock.com/orderitem.asp?it=330ms-069&MnfId=&MdlId=22646
May 20, 2010 | Toshiba Satellite 2775XDVD Notebook
Which ram support for compaq presario c700 tu''
This laptop can have a max of 2Gb of ram, (2x1gb)
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot, None-ECC
Hope this helps.
Aslong as you get 512Mb or 1Gb sticks of PC2-5300 none-ecc laptop ram, you will be fine.
Jan 02, 2010 | Compaq Presario 700 470024-192 Notebook
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
Need to know mem spd...333...400 etc to add cards
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Nic
Feb 26, 2009 | HP Compaq Presario SR1630NX PC Desktop
Upgrading my fujitsu amilo pro v2010
Hi Brian,
It's not a problem as u think..
Yes your Ram is 256 M.B // but your Vga Card is built in the mother board with 64 M.B ..so it's share the Vga card Memory from ur basic ram (64 - 256 = 190~192 M.B) .
So u just need to increase ur rams by new one or replace this ur current ram by 2g.byte ram .
best luck.
Nov 29, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Upgrade ram on 12XL125
Specifications for the Compaq 12XL125 state that the system memory is:
64 MB 100 MHz SyncDRAM, shared memory architecture, upgradable to 192 MB - 4 MB dedicated for video memory
This system will not be able to use the ram you are trying to install.  For more about this system go to this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013744&lc=en&cc=us&product=95040&dlc=en
Aug 16, 2008 | Compaq Presario 12XL125 Notebook
E-Machines eMachines T3830 PC Desktop Logo
67 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
