Question about Maytag Washing Machines
Water sometmes runs on the floor during a fill cycle. I need to remove the top to check the water solenoids or hoses etc.
  • 3 Answers
If it happens on the fill cycle only would that mean you are in need of a pressure switch?
Posted on Jun 03, 2009
Front loader leaking underneath in the back corner on the left hand side
If its leaking during the fill cycle, its one of the water valves (solenoids) or associated hoses, loose clamps, etc. If its leaking during draining its the drain hoses, pump, clamps etc. Easiest way to tell. Pull it out, if you can remove the back, run it and look for the leak. Just don't touch anything while its running, you don't want to lose a finger or get electrocuted.
Aug 06, 2014 | Samsung Front Load Washer Control Board...
Noisy Hoover hed6612 dishwasher
Con you check to see if the insulation over the top and sides of the dishwasher was touching the floor and wicked up enough water to get wet? That would reduce the sound dampening characteristics. It is also possible that the hose being shaken off was caused by an issued with something jamming the pump; check the drain grates to see if there is anything you can pull out.
Jan 27, 2014 | Frigidaire 24 in. FDB635RF Built-in...
Why doesnt my washer put out cold water
either the hose screen inside the fill hose is plugged with lime/rust/etc. or the water solenoid is defective or not getting power from the controls,on some fill valves there is a thermistor that senses water temps as it fills and this part could also be defective,you can test this valve with a cheater cord to see if it opens,or unplug the machine and use an ohmmeter to test the solenoids coil for continuity,if good plug it in and check for voltage(normally 120 volts A.C.)on the solenoids terminals during the fill cycle
Nov 19, 2012 | Amana Washing Machines
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
May 26, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
What is the best way to winterize a standard large capacity washing machine?
If the product will be exposed to sub-freezing temperatures, turn off the water supply to washer, disconnect fill hoses, drain them and reconnect. Remove the drain hose from the standpipe in the wall and place it into a shallow pan at floor level untill the water floe stops. Unplug unit and you are good to go.
If no sub-freezing temps are expected, turn off water supply. Turn on washer for a warm wash cycle for a few seconds to relieve the pressure in the hoses. Turn off machine and unplug it.
Nov 04, 2009 | Kenmore 22422 Top Load Washer
My Neptune does not fil with cold water during the
Check for a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris (especially the cold water side) and check the solenoids. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Sep 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
During the fill cycle, the washer leaks water?
I've repaired leaks from bad rubber washers on the fill hoses as well as loose hose clamps on the back of the fill solenoids that run into the tub. Check closely.
Jun 27, 2009 | Maytag Washing Machines
Water runs contiuously... tub never fills...cycle doesn't start.
Hi, You need to reset the drain hose. It needs to be over the water level in the machine. If you have it in a sump pump, it needs to be out of the water in the sump. If I can help you further, please let me know
Thanks
Vic
May 16, 2009 | Roper RTW4100SQ Top Load Washer
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
