Question about GE Spacemaker JVM1540 Microwave Oven
I need a charcoal filter
I just purchased a microwave oven, model JVM1540DM1WW , and I need to find the correct number for a charcoal filter and where to purchase it.
Thank you for your help.
Ben
    Problem Solver:
  • 11 Answers
Thank you for your post Scott! I manage a ton of properties and worked with www.RangeHoodsFilter.com , they were VERY helpful and gave me discounts with quantity purchases. I order 20 then 800 range filters for our GE models. YOU ARE right, you order by part # and it is like a lottery if you get what you need. Quality, low cost and most important,,,THE FILTERSFIT.
Thanks again for your post! Buyers beware of ordering by just the part #. Measure and call them at 1-888-279-1670. One last thing, they also sell HVAC filters too . Custom sizes for all filters. I am very happy you saved myself a lot of time by your post.
John
Posted on Oct 08, 2009
  • 4 Answers
The GE spec sheets for what is the right charcoal filter are incorrect. You will never find the right one. I have this same microwave and had same problem. I called a local appliance company and they gave me Part No. WB06X10359 and when I googled this part it was not the right dimensions. I finally found the perfect solution. Go to www.rangehoodsfilter.com (Filter Factory-TTN Inc.) and they are customing making the filter for me. I spoke to Dave this morning from Filter Facotry and he's making me one with the following dimensions - 5 7/8" x 13 1/4" x 1/4". The cost is $16.95. If this fits I will order more. The more you order, the cost per unit goes down.
Posted on Jul 19, 2009
  • GE Master
  • 9,098 Answers
You can download your owner's manual here.
For just the charcoal filter, order Part # WB02X10776, which you can order here.
Filler Panel Kits are also available
JX46WH/BL—White/Black
JX40WH—White
JX41—Black
When replacing a 36′ range hood, filler panel kits fill in the additional width to provide a custom built-in appearance.
For installation between cabinets only; not for end-of-cabinet installation. Each kit contains two 3′-wide filler panels. JX81C—Recirculating Charcoal Filter Kit (included with Model JNM1541) Filter kits are used when the microwave oven cannot be vented to the outside.
Posted on Jun 03, 2009
How to remove grease filter from a Samsung over the range microwave model number smh8165st
The support page for model SMH8165S is here, and the first solution listed is how to replace the charcoal filter.
You can also download your owner's manual.
The charcoal filter is part number DE63-00367A and you can order it from the Pros here.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
May 01, 2017 | Samsung Microwave Ovens
How do you remove grease filter from Samsung over the range microwave model number smh8165st?h
pupista@gmail.com
Amana Microwave over the stove. Need to replace light bulb. So what is the part number?
If the model number is correct in your post and I assume you are talking about the over the range light and not the cavity light then you need 53001905 halogen bulb, charcoal 53001442 still available
Jan 17, 2015 | Amana AMV5206AAS Microwave Oven
I don't know how to replace the charcoal filter on my Frigidaire FMV157GC microwave. There's also food between the grate and the glass on the microwave door. Help !
This is billed as the Use & Care Manual for the Frigidaire FMV156DC Microwave Oven:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Springfield/316495004en.pdf
Not sure it is the correct one but you will find instruction for cleaning the exhaust filters on page 19.
Below is the Use & Care Manual for a model direct from the Frigidaire site:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316495057en.pdf
This is more helpful as on page 20 it includes illustrated instructions for removing the charcoal filter to change the oven light. Disconnect from power, remove the ventilation grate at the top to access the charcoal filter, slide back and lift to remove. With the grate removed carry out any required cleaning.
Mar 20, 2011 | Frigidaire FMV156DC Microwave Oven
Model:JVM1631WJ03 Serial: RH900768U How complicated to replace inside bulb. I am a female senior and greatly miss having that light. Also where to purchase that bulb?
It's pretty simple.
It's covered on page 33 of the service manual found online here.
You can pre-order bulbs by entering your full model number (JVM1631WJ03) here.
1 To replace the oven light,
first disconnect the power
at the main fuse or circuit
breaker panel or pull
the plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
See video here.
3 Remove the charcoal
filter (if present) to
access the light cover
(see Remove Charcoal
Filter section).
4 Remove the light cover
located near the center
of the oven that holds
the bulb. Remove the
bulb by gently turning.
Replace with the same
size and type bulb.
5 Replace the light cover
and charcoal filter
(if present).
6 Replace the grille and
screws. Connect electrical
power to the oven.
Aug 21, 2010 | GE Advantium 120 Convection/Microwave Oven
Wrong Grease Filter for Sharp R-1870 Microwave
I also have a Sharp over the Range Microwave oven that requires a charcoal filter. But my diagram shows that the charcoal filter goes behind the slotted panel at the top of the microwave. To reach the filter, you must remove a screw on the top edge of the microwave. This allows the panel to come off. Your charcoal filter goes there. Since your oven is new, you do not need to change this filter yet because it's not dirty. I would save it for future use.
According to my book, there are two kinds of filters with this oven. The charcoal filter is the one behind the front panel. The Grease filters ARE the two metal mesh ones. They can be cleaned with hot soapy water, or I put mine in the dishwasher.
Mar 14, 2009 | Sharp R-1480 Microwave Oven
When opening the door a venting sound immediately starts up.
The charcoal filter needs to be changed every 6-12 months, or sooner if it gets clogged.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts (including charcoal filters) by entering your full model number from the tag on the oven here.
Feb 11, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1540 Microwave Oven Logo
719 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
