Question about HP LaserJet P3005 Printer
Repetitive paper jam in the fuser area in a LaserJet P3005dn
Well i have this problem on two P3005 now and i heard that some other people got the exact same problem, but only with this printer model.
I've never seen this problem on any other HP Laser Printer yet, and we got many 2420, 2430, 2100, 2200 and 2300 printers. Even on P2015, never got this serious problem.
So it starts with intermittent jams, but you need to shut down the printer and start it again to fix the problem. Then it's all the time.
So as i said i have two printers with the problem, one i cant use anymore, and the other one still works for now.
What happens exacly is that the paper is taken up to the toner and goes all the way to the fuser but stops there. In fact, the paper is folding trying to enter the fuser. The page is completly printed but has never got in the fuser so the ink isnt dry yet. So to remove it i have to gently pull the paper towards me but i would say that not even 1 inch of paper was in the fuser so it goes out easily.
So i tried a cold reset, then tried a different Fuser and an other toner cartige but still nothing. I start to suspect something about the fuser gears or motor.
Any ideas?
  • Martin Metivier
    Martin Metivier Jun 04, 2009
    Hi, thanks for the answer. Can you be more specific about the solution on this one?
    i'm not familiar with some terms here, what's the upper film and should i try to clean the gears or something else?
    thanks, that would be very appreciated
    President:
  • 3,085 Answers
Your lower press roller in the fuser may not be turning all of the time since it is driven by the upper film. Rough them up with Scotch Brite Pads
Happened a lot on hp 4000's
Posted on Jun 04, 2009
Take apart hp3005dn
Analyse what type of jam it is...based on that we can shoot the trouble.1. Paper is jamming before entry in fuser and its folds like curl in the cartridge area.. A. Fuser Teflon sleeve not rotating or slow rotation results media(paper)unable to reached the destination in specified interval. Replace fuser assm or Teflon sleeve.2. Paper jamming after fuser assembly crossed little bit ( approx 1-2 inch).A. Clean fuser out paper sensor, check sensor flag & flag spring located in fuser assm.3. Paper jammed after fuser crossed more than 6 inches..A. Check paper pick up roller warn out(tray1 or 2), check registration sensor located under registration assm.How to remove fuser assm: remove back door, see the snap shot...
Registration sensor location:
Pick roller roller tray 2 :
1_9_2012_3_54_49_pm.jpgPl try it carefully..Best of luck...
Jan 09, 2012 | HP LaserJet P3005n Printer
P3005 jams
Post the exact error message indicated on the printer LCD. 13.01, 02 paper feed issues, worn rollers or jammed paper inside of paper feed assembly.13.05, 06 fusing assembly issues, broken sensor flag in fuser or worn busing on fusing rollers (fusing assembly will be noisy or making grinding sound.) If this the issue being noisy, the fusing assembly has to be replaced along with one of the drive gears, about a 30 min. of work.
Sep 30, 2011 | HP LaserJet P3005 Printer
I have problem with hp laserjet p3005 with paper jams inside fuser assembly, i already clean the rubber roller then still the same problem occure...please someone help me.....sorry for my bad english
If you are getting jams in the fuser, then there may be paper stuck in there, or the roller sleeve is damaged or the drive gear could be bad. You are going to have to take the rear cover off to look at the fuser.
Someone trained is going to have to remove the fuser to inspect it.
Jul 13, 2011 | HP LaserJet P3005 Printer
13.01.00 Jam in Tray 2 error when no jam exists
Check Tay2 paper sensor flag, located at tray2 pick up roller, its its stucked shoot the fault
Mar 24, 2011 | HP LaserJet P3005 Printer
Paper jam in HP printer p3005n printer in between paper sensor+fuser assembly & toner
These printers have a problem with the bushings on the fuser, as they wear the gear drive moves away and you nolonger have drive to the fuser. HP has a kit, you replace the fuser and the gear driving it. At the same time, you should also replace the feed roller, both are simple to do with a phillips screw driver.
http://www.precisionroller.com/fuser-assemblies---units-for-hp-laserjet-p3005/products.html
for your parts.
Jan 16, 2011 | HP LaserJet P3005n Printer
Jam inside top cover 13.05.00 also change fuser assembly
To remove paper jam. Just remove the toner cartridge and pullout jammed paper. If still coming paper jammed error message. Switch of the printer and the printer will roll over the paper jammed.
Changing of fuser drum is required if the print out came with the black strips. This happens when you print large volume of printing jobs.
Nov 26, 2010 | HP LaserJet P3005 Printer
I just replaced the Fuser as well as a new Toner cartridge in my HP Laserjet P3005. Getting an error message after initializing that states "13.20.00 Jam Inside Rear Bin". I've taken it all back apart and...
First, make sure that both wire connectors on the right side of the fuser are seated correctly.
Then, see if there is paper sticking a little way out of the fuser. If so, chances are the exit sensor in the fuser is not functioning correctly.
You can put the old fuser back in and verify this if no error codes come up.
Oct 25, 2010 | HP LaserJet P3005d Printer
Seems to jam in fuser, fuser has been replaced
if it always jams at the same place (fuser area) try another fuser or check the BLACK PLASTIC ASSY. THAT is mounted in the left door and takes the paper right after it comes out of the fuser ;part is called (PAPER DIVERTER) And sometimes one of the FLAPS That routes the paper is broken,hence causing paper jam.
Jul 30, 2009 | HP LaserJet 9050 Printer
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
HP LaserJet P3005 Printer Logo
744 people viewed this question
Seeker5211
Seeker5211
