Question about Acer Aspire 5102WLMi Notebook
My Acer Slide Latch is broken on my 5315-2698?
My Acer Slide Latch is broken on my 5315-2698 Notebook. Not the spring itself. I tried calling Acer to see if it would be under warranty and they wanted to charge me 500.00 usd for JUST a plastic peice. Its the button the slides to the right that broke off not the spring itself. If I open it without my button I will have to use a screw driver. Please Help? Any place for me to know where to get the peice?
Acer computer company is run by chimpanzees
Posted on Sep 18, 2009
I have the exact same problem as bcvroman
Posted on Sep 16, 2010
Why do no panel lights turn on when my Kenmore Model 587.1625 is latched and ready
The door latch in Kenmore and Kitchenaid isn't of the best design.The spring steel latching tab is needs to push down the black plastic slide mechanism when the door in closed. That slide pushes down on a micro switch which interrupts the cycle when you open the door when the dish washer is running. Take the latch assembly back out. You can insert two compression springs inside the slide on each side of the latch. They are approx 3/16 Dia x 3/4 to 1 inch long. In the hardware dept at Home Depot or Lowe's..The springs will push the slide down hard enough to activate the switch. Right now your dish washer thinks the door is open.
May 17, 2014 | Dishwashers
Battery slide wont open
Does it have a locking mechanism? The Latch/spring may be broken or jammed, push the latch over and hold use a tool, old credit card, to wedge at the crack where the battery meets the laptop, gently pry it open, while holding the latch open. OR remove the laptop's bottom cover. If you supply the Model of the Compag , I may can assist you further.
Feb 27, 2013 | Compaq Presario Notebook
2003 Toyota Corolla. Trunk won't stay closed. Latch seems to work fine.
must have a broken spring in the latch tha'ts how it works a spring keeps the locking teeth together.replace the latch.
Nov 25, 2010 | 2004 Toyota Corolla
The latch on the laptop broke How do i open it?
you need to mimic what the latch did most latches are like arrows in this case get two thin items ( blunt butter knifes) and move the latches both left or right if its a middle type latch then try pushing in were the broken latch was .get what i mean if the old latch pushed in then its a middle latch if it slide then is double arrow latch ounce the laptop is open if you dont want to spend $$ fixing the lach just cut of the locking arrows to stop it locking again
good luck
email me if need further assistance
Jun 25, 2010 | HP Pavilion dv1000 Notebook
1998 subaru legacy hood latch is broken :(
tre spring is on the latch itself,my guess is that the latch needs a little lube,work the area of the latch that the cable slides into with a screwdriver,it should spring back after you lube it
Sep 11, 2009 | Subaru Loyale Cars & Trucks
Cant open laptop
should be a slide latch on the front of it.
Mar 19, 2009 | Acer Aspire 5315 Notebook
Flash does not open when I slide the "open flash" switch.
Try gently lifting the flash with the flash latch held open. It may have grit stopping it or a broken spring. Also make sure the latch is pulling right across to the right.
Dec 02, 2008 | Kodak EasyShare DX7590 Digital Camera
Acer Latch is broken
On most notebooks, there is a VERY small return spring (smaller than a spring from a ball point pen) on the latch that tends to break.
Apr 20, 2008 | Acer Aspire 5102WLMi Notebook
Acer Aspire 5102WLMi Notebook Logo
831 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
