Question about Mitsubishi WD-62528 62" LCD HDTV
Crooked picture Just replace a lamp on my tv and now the picture is crooked (banners, graphics, side panels and the entire picture box is noticably crooked.
  • Mitsubishi Master
  • 8,457 Answers
Reintall the lamp,probally install it not correctly seat it.
Posted on Oct 29, 2009
    Sergeant:
    Champion:
  • 223 Answers
Go into your view options in your menu and use the remote to center your screen.
Posted on Jun 03, 2009
Installed new lamp, now picture is tilted/crooked.
IS the set sitting on a flat surface that completely supports the base at the bottom and is level?
Do a little experiment, with set on lift up on either side of the cabinet at the bottom and see if picture gets straight--not a joke or a prank.
Dec 13, 2012 | Mitsubishi WD62628 62" Projection HDTV
Electric window goes up crooked
Hello there patsey! I've seen this many times before. It sounds like a window track problem. The window glass rides up and down inside the trackwork channels. Those channels sometimes bend or break and cause the window to run crooked. You wont really know for sure what the exact problem is until the inner door panel is removed so you can inspect it. Best case scenario is the track bolts have come loose and just need tightening ($50-$60 repair). Worse case scenario is that the entire window track or window regulator assembly needs replacing. This can sometimes run upwards of $200 or more. BTW, removal of the door panel just to inspect it should run no more than around $30- $40. Hope this helps.
Oct 06, 2011 | 2000 Pontiac Montana
I have arear projection Hitachi big screen that has an unlevel picture. Crooked a bit. How can I manually fix this?
Very common problems for DLP tvs,will get worst as times go by.Tv probally have a problems known as a convergence problems,it is dead.Tv have colors lines R,G,B unlevel on the pictures?Crooked pictures have mis colors alignments?Yes.There is no way manually to do an adjustment to fixed for this.Try push the tv remote button that said Magic Focus button.If the tv have data processing never completely done and have a error message and stop.Ur tv 100% have a dead tv convergence board,the tv convergence board must have it parts to be replaced like 2 STK convergence ICS and some or all of it resistors too.Than tv will be able to run the tv remote Magic Focus again to have a 100% data processing with no error message,tv to fixed this problems.The shop will cost u like $300-350 for parts and labors.
Jul 17, 2011 | Hitachi 61SWX10B 61" Rear Projection...
Lamp changing Instructions for tv model wd-52525
Hello
Unplug your Mitsubishi DLP TV and position the unit so you can easily access the back
Locate and remove the screws for the back panel. Do not remove the entire back of the TV but the lower panel only. The screws will be located in the edge of the panel.
Locate the projection box in the center of your DLP TV. The projection box will have a series of wires coming out of it and be attached to the speaker housing with four screws
Remove the four screws holding the projection box in place and slide the projection box out. It will not come all the way out but will slide out like a drawer. Disconnect the electrical wires at the projection box by pulling the connectors apart. You should now be able to see the projector lens itself.
Facing the back of the DLP TV, the lamp box is on the right side of the projector lens. Pull the lamp box to the right and it will slide away from the projector lens
Grab the top of the lamp box firmly and pull it out of its spring holding clips. Replace it with your new lamp box by pressing the new box into place in the same manner as the old one. Finish the job by reconnecting and installing everything you opened or removed
Mar 18, 2011 | Mitsubishi Televison & Video
I am trying to hook up my stand to my LG 32LD450, and it appears that the main bottom piece is crooked so the tv will be crooked, is this fixable?
We had the same problem, when you put it all together the base swivels! Problem solved, Merry Christmas.
Dec 24, 2010 | LG Televison & Video
Picture goes blank AND SOUND goes off together, both back on too
it can still be the lamp for some reason these sony tv's will exibit these symptoms when the lamps are getting weak. by the way when the lamp goes out the entire tv shuts off no video or audio, just to let you know.
Aug 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Philips 46 Rear Projection convergence off on part of the screen
you may have bumped the alignment rings on the convergence yoke on the red tube while doing the coolant as that could cause the symptom youre describing.
Aug 25, 2008 | Philips 46PP9302 46" Rear Projection...
Picture is crooked
A year, to 1.5 years is very normal for bulbs. Just remember they are rated by the hour. The more you use it the faster the bulb goes out.
To fix the picture
NOTE: The TV must be on a flat level surface.
1. From the front of the TV, lift the foam to access and loosen slightly, the brass Rotation Locking Screws on the Adjuster
Assembly, (Use a 10mm wrench.)
2. From the rear of the TV, access the black Rotation Adjustment screw and adjust so the test pattern center lines are
parallel to the sides, top and bottom of the screen frame, (Use a mirror to veiw the picture from the rear of the
set.)
3. Tighten the two Locking Screws. Use Locktite to secure the Adjustment Screw.
Jun 14, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Crooked screen
do you mean the screen assembly itself is crooked or just the picture is crooked?
May 18, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Tv is crooked
you can do this through the service menu but not reccomended because something electronic is making it do this and needs to be fixed is all three colors that are doing this or just one
May 06, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-62528 62" LCD HDTV Logo
858 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
