Question about Cameras
Canon eos 350d has no display, when the battery is inserted the shutter opens and closes and the blue led in the backlight button glows continously, can you help please. Kind Regards Bill.
  • mrbillthomas Jun 03, 2009
    I have not tried this yet but I shall get back to you.
    Kind Regards Bill.
    President:
  • 1,383 Answers
Your meory card has some issue .
First reset alll settigns to factory defaults.
Press power button for 10 seconds then it reset.
Then remove meory card from it.and start camera without memory card.
Let me know please.
Posted on Jun 03, 2009
Tokina canon eos 350D error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 350d service manual link:
http://goo.gl/ELh523
it will help you to save a lot of money
Hope it helps, Thanks
Apr 08, 2013 | Tokina AT-X 124 PRO DX Lens for Canon
Err 99
Hello hemantp. This error code in this model indicates that the lens electrical contacts are dirty or slightly oxidized. To clean them you will need a common pencil with a clean eraser on the end and a lens cloth.
Detach the lens from the camera and hold it so that the lens' gold contacts are pointing down. Lightly "erase" their exposed surfaces and then clean them with the lens cloth to remove any debris.
Do the same with the gold contacts inside the camera body. Although this is a wee bit more challenging, you can do it by holding the camera so that the lens opening points down. That way no debris will fall inside as you clean. Joe
Nov 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Brand new canon slr camera. can't see a live pic on led
Canon 350D can only take picture it does not take video. On screen of course you can play the photos you have taken. But that is all.
Feb 28, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 in canon 350D
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Techincal
You should be able to set the exposure to "B" when the exposure is set for manual exposure settings. The shutter should stay open (and the mirror up) for as long as you keep the shutter button pressed.
Mar 12, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Auto focus does not work in creative modes
That is a custom function of the camera that can be change back to default with ease. While in one of the creative zones press the menu button and navigate to the 5th and final tab on the top right. 8f5da8f.jpg
This is the Setup menu 2. In this menu, select “Custom Functions (C. Fn)” . This will open a submenu of numbered options. Select #04 and set it to 0: the default AF/AE lock on a half depress of the shutter. 7528356.jpg
That should get your camera back to the expected auto focus with the shutter button.
Mar 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Camera features canon 18-55 digital cmera EOS 350 D
It does different things depending on the camera settings and only works in the creative zone settings not the automatic settings.
In AV mode it changes the aperture
In Tv Mode it changes the shutter speed
In M mode it changes the shutter speed unless the AV button is pressed when it then changes the aperture
Apr 06, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Rebel 2000 went retarded
I got a Rebel 2000 off ebay, and it had the same problem. The Shutter wouldn't open, it showed dead batteries, and the mirror hung until I pressed the shutter button or changed modes.
After a good deal of surfing, I found that the most likely reason was a sticky/oily shutter
(http://photonotes.org/articles/oily-shutter/).
Since I didn't have much $$$ invested in the camera, I tried cleaning the shutter curtain with Qtips and alcohol. After a little cleaning, the shutter started to move. After a lot of cleaning, the shutter moves freely. I ran a roll of film through it, and it seems to be working just fine now.
Feb 27, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Shutter opened but won't close
Switching off the camera from the main ON/OFF swit5ch should close the shutter. If it doesn;t, try removing the battery or the CF card. It is possible to manually increase the shutter speed even in bright sunny conditions.
Jan 09, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
49 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
