Question about Microsoft Xbox 360 Console
My new shop vac won't shut off without pulling the plug out of the wall????
  • 90 Answers
Dude this is for xbox consoles; not vacs. What you need is a good vac. you get what you pay for.
Posted on Aug 04, 2009
HOW TO DEFLATE THERAPURE SPA
fastest way is use a wet/dry shop vac , just place the tip of hose over inflation valve and it will draw air from walls (fast!!)
careful if using a home vac system , as some water might be inside walls and home vacs don't like that too much , wet/dry shop vacs are best 4 this
Dec 21, 2013 | Therapure Four Person Inflatable Round Hot...
Bypass power switch
You should simply purchase and install a new switch. It's not safe to bypass the switch as when you do, the entire electrical load is placed on the wall prongs when you plug in or unplug the vacuum. Depending on the brand of vacuum, you can easily order parts and replace the switch at a nominal cost.
Nov 08, 2013 | Shop Vac Vacuums
Switches will not turn off unit. model #cv450w
If the switches on the hose will not turn off the vac you have a short in the wiring of the vac pipe system or a defective relay on the circuit board. Plug the vac in again without the hose and disconnect the thin low voltage wiring were it plugs into or screws onto the vac.
If the vac continues to run once disconnected from the low voltage circuit you have a defective relay in the vac itself. Some are circuit board mounted , others freestanding. To avoid a service call you can take the tank off the wall and take it to a pro shop or remove the top hosing if you are confident and check out the relay for a replacement part.
If the vac stops your issue is in the house. Has any painting been done or any inlets removed lately.. check that area first for a short at the inlet. Go back to any and all inlets and remove them one at a time checking the mounting screws and backing plates for loose wiring which is touching either the metal inner wall plate in the wall or a common screw . Test the vac as you go.
If this does not help, you will need to examine the wiring in the house , running along the pipe. Again if anything has been disturbed recently, near the vac, or near any piping that would be your first suspect area.
Post back to advise.
Oct 18, 2009 | Broan-NuTone CV350 Central Vacuum
My kirby legend II started spitting out sparks near the foot plug. How can I fix it please? Thanks Candy
Depends where the sparks are spitting from.Unplug from the wall and try to detach the cord from the vac itself, where it plugs in. If there is a small hole burned in the side you will need to detach the entire cord from the handle where it clamps on and buy a genuine new one from a vac repair shop or Kirby dealer. Cords do wear out. Ther is a slim possibility you could have a bad switch below but generally the switch just dies , no sparking.
If the sparks were shooting out from inside the motor housing, you will likeley need a motor rebuild which should be done by a professional at vac shop.
Oct 04, 2009 | Vacuums
Central Vac does not shut off
Sounds like the relay that is in the central vac unit is stuck to the ON position. When you plug it back in..does it start right up ? If so.. You should be able to disconnect all the receptacle feeds to the central vac unit at the central vac unit to determine which one ( if any) is calling for the vac to stay on.. if none are.. then it is internal to the vac and may be a stuck relay... Hope that gives you some ideas to check...
Aug 28, 2008 | Vacuums
Kenmore Ultra Fabric 80 HvyDty machine won't drain (much)
probably bad motor ..motor overheats shuts off on safety after cool down comes back and repeats cycle
May 02, 2008 | Kenmore 80754 Top Load Stacked Washer /...
Microsoft Xbox 360 Console Logo
87 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
