Question about JBL CREATUREIIWHITE Computer Speakers
Volume controls don't work on my Creatures
I have the same problem.. in that my volume controls don't work but I just get a slight buzzing sound when I press them.
I have the same problem, i know this post is quite old but did you manage to fix it? if so how?
Posted on Apr 16, 2010
Behringer K3000FX Ultratone Keyboard Amplifier from day 1 has had a slight buzz
For a start , check headphones out.
• if it don't work , check power supply of the preamps.
• If it is OK, could probably the main amp have fail.
But check the main volume .
Sep 11, 2012 | Behringer Ultratone K3000fx 300w Keyboard...
No sound on toshiba 36 tube TV
Check its speaker/s. If it is OK, the audio output IC should be checked.
Jul 14, 2012 | Toshiba 36A43 36" TV
I own a A/Lansing FX 6021, My right satelite speaker is not working( no sound, no buzzing at cable plug-in), are there any solution for this problem??
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 05, 2011 | Altec Lansing FX6021 Computer Speakers
Computer crashed,i changed the hard drive and now i have no sound
Check that they are plugged into the Green socket. Open Volume control from the taskbar and check that Wave and Volume controls are turned up. If still nothing, check the speakers by plugging headphones in in place of them. Hope this helps. :)
Jul 20, 2010 | Dell Dimension™ E310 PC Desktop
One speaker no sound
I just want to confirm that the solution on another page from francis 8 works perfectly ( http://www.fixya.com/support/t3709832-speakers_stopped_working_cannot ). We have two sets of Creatures in our offices, one had been shelved (by someone less persevering than me) due to this problem years ago and my set started this trouble a few days ago. Troubleshot everything, every cable, setting, combination, spare speakers etc - nothing worked. Opening the offending speaker and pulling back the metal weight behind the speaker cone was the solution for BOTH of our units.
Big smiles all around :-)
Note - When you've opened the plastic shell and loosened the speaker from its mounting, the the big round metal piece/magnet sits within the actual speaker 'cage', slightly behind the speaker cone. It's tight but movable and can be pulled all the way back as far as it can go inside it's housing, away from the speaker cone.
Not sure why it gets pulled forward, but it isn't fixed in position and so could clearly get bumped by dropping the speaker or a reasonable impact of some sort. Once bumped forward it would severely limit cone movement and therefore volume.
May 07, 2010 | JBL CREATURE II Computer Speakers
Acertravelmate4000 got it used,don,t know how to turn off mute,turn on or up volume
The volume may be muted. In Windows, look at the volume
control (speaker) icon on the taskbar. If it is crossed-out, click on
the icon and deselect the Mute option.
The speakers may be turned off. Press Fn-F8 to turn the speakers
on (this hot key also turns the speakers off).
The volume level may be too low. In Windows, look at the volume
control icon on the taskbar.
Fn-? Volume up Increases the sound volume. Fn-? Volume down Decreases the sound volume.
If this helps u let me know
regards
Jan 12, 2010 | Acer Computers & Internet
Buzzing sound coming from TV Speakers and any external speakers
change your pre-amp ic sure it will work. or maybe cold solder from the board.
May 05, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Brand new LC 42D65U
Sounds like your powerboard, take it back or call tech for replacement, dont settle for this, you paid good money for a working tv
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sanyo tv ds25390 buzzing sound
I had the same problem with the same model.
The solution was to replace a capacitor, C622, which is located near
a small blue rectangular plastic component.
This component is a relay that is controlled by C622. I paid $2.39 for
the part, $8.99 for S&H for a total of $11.38. This fixed my problem!
May 26, 2008 | Sanyo DS25390 TV
I want my music back!
Have you tried to raise the volume by double clicking on the speaker icon on your taskbar. This will open the play control panel where you can raise the volume.
If you do not see the speaker icon, go into your control panel and chose sounds and audio devices and raise the volume from that screen.
Mar 31, 2008 | Gateway 2520915 Keyboard
JBL CREATUREIIWHITE Computer Speakers Logo
169 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
