Case loader the front knuckles are leeking oil bad.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Change the seals. They are worn out.
Posted on Oct 25, 2007
Front right hub and sensor assembly or a diagram
Removal Steps
1. Torsion bar
2. Wheel speed sensor
(if equipped with ABS)
3. Back plate
4. Lower ball joint
5. Upper ball joint
6. Knuckle assembly
7. Oil seal
8. Thrust washer
9. Needle bearing
10. Knuckle
Installation Steps
10. Knuckle
9. Needle bearing
8. Thrust washer
7. Oil seal
6. Knuckle assembly
5. Upper ball joint
4. Lower ball joint
3. Back plate
1. Torsion bar
Mar 01, 2011 | 1999 Isuzu Trooper
How do i pull the hub off my 2002 mazda , on drivers side front
REMOVAL & INSTALLATION Except Miata FRONT
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Steering knuckle from the vehicle
    • Inner oil seal from the knuckle
  3. Using Mazda Hub Puller tools 49 G033 102, 49 G033 104 and 49 G033 105, pull the front wheel hub from the knuckle assembly.
  4. Remove or disconnect the following:
    • Bearing inner race from the front wheel hub
    • Retaining ring from within the knuckle
    • Front wheel bearing from the knuckle, using the hub puller tools
    • Brake dust shield
  5. Clean and inspect all parts but do not wash or clean the wheel bearing. The bearing must be replaced. To install:
  6. Using Mazda Press tools 49 G033 107 and 49 H026 103, install a new dust shield cover assembly to the knuckle.
  7. Using the press tools, press a new wheel bearing into the knuckle assembly.
  8. Install or connect the following:
    • Wheel bearing retaining ring
    • New oil seal using Installation tool 49 V001 795
    • Front wheel hub using the Mazda press tools
REAR
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section. NOTE: The wheel bearings are not serviceable. If the bearings are bad, a new hub/bearing assembly must be installed.
    • Rear wheels Fig. 1: Exploded view of the rear wheel hub and bearing assembly (disc brake model shown, drum is similar) 7923mg87.gif
    • Brake drum, if equipped
    • Rear caliper and rotor assembly from the hub, if equipped
    • Hub dust cover
  3. Raise the staked portion of the hub retaining nut with a hammer and chisel.
    • Hub retaining nut and discard it
    • Hub and bearing assembly from the spindle Fig. 2: When installing the new hub nut, be sure to stake it into the notch on the spindle 7923mg86.gif
    To install:
  5. Install or connect the following:
    • Bearing assembly on the spindle. Torque the new nut to 131-173 ft. lbs. (177-235 Nm)
    • Stake the nut into the groove in the spindle
    • Dust cover
    • Assemble the brakes
    • Rear wheel
Jan 01, 2011 | 2002 Mazda Protege
My washer leeks from the bottom, slow drips,when in progress. Can I fix this myself
If you have a leaking FRONT LOADER, you will need to remove the lower toe panel under the door and inspect the washer interior cabinet to sufficiently determine where the source of the leak may be coming from. The following link explains how to access and inspect your washer for leaks:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In the majority of the cases with front loaders, the door bellow begins to leak. A routine inspection of the seal perimeter will tell you if there are any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Make sure you throughly check all drain hoses, hose connections, the pump seal and the dispenser hose(s) that penetrate the door bellow.
These problems can easily be repaired without the assistance of a repairman. If you have any questions, please post back and let me know. I hope this helps you.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite top loader skakes bad it is level drum sets to the left off balance bad
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My duet front loader will fill with a large
there are two water valves above the soap drawer, that are sping loaded to stay shut when power is off. if the water pressure to the machine has increased, sat due to an increase in main pressure from the water board fixing a leek further up the supply, then this could force open the valves. try turning the stop valves at the inlet pipe end, away from the machine, down a quarter turn and see if this stops it.
Oct 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need help replacing front hub
Here's the steps....getting some pics for you....hang on a minute or two.
Front Hub Removal & Installation To Remove:
  1. Remove steering knuckle.
  2. Using a suitable slap hammer, remove wheel hub assembly.
  3. Using a suitable bearing press, remove outer bearing, oil seal, outer bearing race and preload spacer.
  4. Remove inner oil seal, inner wheel bearing and inner bearing race.
NOTE: It is not necessary to remove dust cover (back plate).
To Install:
  1. Using a suitable bearing press, install bearing races in steering knuckle.
  2. Pack the bearings and hub area with lithium grease.
  3. Install inner bearing in steering knuckle.
  4. Lubricate lip of NEW inner seal and press seal into knuckle.
  5. Install preload spacer into bore.
  6. Install outer bearing into bore.
  7. Lubricate lip of NEW outer seal and press seal into knuckle.
  8. Using an appropriate tool, support inner wheel bearing and press wheel hub into knuckle with a force of 2500kg.
  9. Install NEW inner seal.
  10. Install knuckle assembly.
May 13, 2009 | 2004 Kia Rio
Oil Leaking
i believe your oil filter is on that side. try wipeing that area down to pinpoint where its leeking. if it is the oil filter just tighten it up a half turn unless its really leeking then pull it off and see if the seal is still on the filter.
Apr 25, 2009 | 2003 Pontiac Grand Am
Front hub is stuck to knuckle. trying to replace hub assembly because of bad bearings. can not remove hub assy. how do you get drive shaft out of the way? 2003 saturn vue v6 awd.
spray with penetrating oil and let sit. hit with a big hammer. if it still will not come loose remove knuckle and use a press to remove bearing.
Mar 30, 2009 | 2005 Saturn VUE
Overfowing
If your machine is a front loader it could be leaking from the door if the gasket is not properly on. If its a top loader then it could be overfilling due to a faulty water level control pressure switch. Need yo know which it is.
Mar 09, 2008 | Washing Machines
Loader
Eh?
Your PC case loader has a front knuckle?
Please could you describe this problem in a bit more detail, include a photo if possible, I'd like to see this.
Oct 24, 2007 | Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
