Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Foul rotting vegetable type odor in top of Kenmore refrigerator
There is a foul odor accumulating in the top area of the Kenmore refrigerator & freezer -actually seems worse in freezer area - it's a newer model.  There is no food in fridge to account for this.  Ice maker has stopped working, but that doesn't seem to be a reason for this terrible cooked broccoli odor, though that's the area that's worst -
  • 2 more comments
  • yodelcat Oct 29, 2007
    Thanks so much -
  • Mamafaye Jan 09, 2009
    Rotting foul odor is coming from the freezer compartment of my Kenmore refigerator. I can smell it all over the house. With the doors closed, the strongest odor seems to come from the bottom of the freezer on the hinged side of the door.
  • Mamafaye May 11, 2010
    Just wanted to add that the ice maker is working and all the food in the freezer is frozen.
  • Anonymous Mar 17, 2014
    Noisey damper motor operatio in fridge area.
  • 290 Answers
If the icemaker motor or heater short out it will cause a foul odor. I have never heard it described as cooked broccoli, but it can be pretty bad. Remove the icemaker and inspect the bottom of it where the heater element is and remove the white cover of the motor and look in there. You can take the three screws out of the motor module and see if anything is burned on it.
If you can rule out the icemaker, the next things to check would be the evaporator fan motor and defrost heater. Generally, if a fan motor starts causing an odor it will stop running completely and if a defrost heater goes out it will quit defrosting. It is possible, but unlikely, that something has gotten into the evaporator area and is sitting on the defrost heater so that it is "cooking" during the defrost cycle.
Check the icemaker first, it is the most likely cause of the odor. Post back with complete model number if you need further assistance and we will go through checking everything else.
Posted on Oct 24, 2007
  • Michael  Lindley
    Michael Lindley Oct 25, 2007
    Just wanted to follow up on your refrigerator problem and see what you found out.
    Thanks/Mike
There's a foul odor in my refrigerator when the door is open.
the drain line hole may be plugged with rotten food and debris? do u find any water pools att the bottom?
Sep 22, 2014 | Kenmore Refrigerators
Foul burning odor
you could possible be right on if your frig has an electronic disp control put your nose their and sniff if seem close to what you earlier smelled you solved your problem pcb control '
Aug 20, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Foul dead animal smell from kenmoore side by side refrigerator/ice maker
I'm sorry that I don't have a solution, but we have the exact same problem with an older model KitchenAid side-by-side. Did you get this problem solved? If so, can you share what you did?
May 27, 2009 | Kenmore 50522 / 50524 Side by Side...
Bad smell
clean it with baking soda hot water and hair dryer
Feb 27, 2009 | Frigidaire FRT21H8 Top Freezer...
Foul odor coming from freezer.
Problem was fixed by removing the drain tube- which was full of "sludge"- cleaning it out and the connecting piece. I also removed all the built up dust from all of the coils that I could read. I think the main problem was the stopped up drain tube. The foul odor is GONE!!!
Mamafaye
Jan 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Foul odor coming from freezer. Kenmore model w/ freezer on top.
Clean the refrigerator thoroughly fresh food and freezer under all drawers. Then place charcoal briquettes in each 8 or 10 total. 4 or 5 in the bottom of the fresh food section. leave the for several days. If that doesnt take away the smell consider if a mouse may have gotten into a fan blade and well that can create a really bad smell.
Fridge odor
There are a couple of methods to help remove odors from a fridge. The first is a cookie sheet with baking soda spread across it left in the fridge for several days. The other is something called Activated Carbon. Most stores sell it as a carbon odor filter and it is pretty cheap. It actually works better then the baking soda so I recommend you pick some up and just leave it inside the fridge. You can also put this behind your fridge or wherever you have foul odors. Hope this helps.
Nov 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
864 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
