Question about HP LaserJet 4 plus Printer
Powering up issue
When machine is turned on it stays on for less than a second and then just cuts off...i unplugged and changed the power cord to see if this was the issue. but no good. is there a fuse which needs to be changed and if so, where will you find it.
thanks
  • 105 Answers
This sounds like a classic psu fault this is found under the fuser unit on the back of the printer planty are available on ebay lj 4/4+ are the same psu
Regards AL "alstech"
Posted on Jun 14, 2009
Fisher & Paykel IWL 16 shuts off during all cycles.
I says power cut restarting in 10 seconds
I'm sorry, it is the board, the switch mode power supply is dying.
Every time it starts to do something it power cuts.
Best to get a new motor controller board,
Quote the 6 digit part number under the bar code to get the right part.
Mar 25, 2013 | Fisher Paykel Eco IWL16
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Xerox WorkCentre C2424: turned on, runs thru tests, initializing and then shuts off and starts the cycle again. The cycle continues but never resolves.
1. Power machine off and wait until completely off. 2. unplug power cord from wall. 3. with power cord STILL DISCONNECTED turn machine on and off again. 4. WAIT 60 SECONDS 5. plug power cord back in and turn back on
If this does not resolve the issue call for service.
Hope it helps!
Feb 09, 2011 | Xerox C2424 Copier
When I turn the tv on it stays on for a few seconds, and then cuts off
is the power light or lamp light blinks? if its the lamp then replace it. your tv lamp model # XL-2400. check this link https://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=600259&searchOperation=modelSearch&searchText=KDFE42A10
or if its the power light that blinks then turn off tv for 5 mins. unplug power cord for 1 min. try plugging the power cord directly into working wall outlet. if same, tv needs service. visit eservice.sony.com website to check service option
Dec 24, 2010 | Sony KDF-E42A10 42 in. LCD Television
Printer goes on & off not staying on but a couple seconds
Follow these steps to make sure that all the power systems work correctly.
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif Illustration: Power module c00057913.jpg Illustration: Power cord
    NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
  2. Carefully inspect the power supply for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  3. Disconnect the power supply from the back of the product.
  4. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  5. Reconnect the power supply to the product.
  6. Press and quickly release the Power button (c01602202.gif ) to turn on the product.
  7. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on , the electrical outlet in the original room caused the issue.
    • If the product still does not turn on , continue with the next solution.
Solution three: Make sure that other devices are not causing the issue Follow these steps to make sure that devices plugged into the HP product are not causing the problem
  1. If the parallel and universal serial bus (USB) ports of the HP product have other devices plugged into them, unplug those devices.
  2. Press the Power button (c00636182.gif ) to turn on the HP product.
  3. Monitor the HP product to see if it turns off again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
The power only stays on for a few seconds.
Check for forgien objects on or under the PC board if that dosen't do it you will probably need a tech.
DickyO
Jul 27, 2010 | Lexmark Wheelwriter 1000 Typewriter
My Officejet 4315 All-in-One is printing very very slow How do I fix this problem? I have restarted it and unplugged then replugged it and have restarted the computer and it still prints really really...
The very first thing you need to do determine whether the issue is in the Hardware or in the Software for that on the printer .
1. Load plain paper in the tray.
2. Press the Setup button
3. Press 2 to select Print Report
4. Press 4 to select Self-Test Report . The self-test page prints.
Measure the time (in seconds) it takes for the test page to prints.If the test page prints in less than 60 seconds , this is normal print speed and you do not need to troubleshoot.If the test page prints in more than 60 seconds , go to the next step.
Important ;
Some products print faster than others. If the test page exceeds 60 seconds, and other documents you print typically take as long, the print speed is normal. Troubleshoot this issue only if your product is designed to print faster than about 60 seconds a page or if printing is slower than usual.
***** IF THE PRINT SPEED IS MORE THAN 60 SEC.
Check the power supply. to check the power supply you need to follow these steps.
1. Turn the product so that you can access the rear side.
2. Unplug the power cord from the back of the product.
3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
4. Plug the power cord directly into a wall outlet.
5. Print and time a self-test again.
If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet. If the test page takes significantly longer than 30 seconds to print, continue to the next solution.
CHECK THE CARTRIDGE COMPATIBILTY.
Incompatible cartridges can cause the slow printing problem.
Which cartridges you use depends on your country or region. To check the cartridge compatibility you can go to this site (for hp printers) http://www.hp.com/buy/suresupply and check The number on the cartridge label must match the numbers listed on HP SureSupply.
PERFORM A RESET.
1. Press the Power button and turn off the printer.
2. unplug the power cord. Disconnect the data cable(USB,Ethernet depending upon the the product set up). wait for 30 secs. reconnect all the cable and than try to print a test page.
if these steps resolves the issue than you dont need to continue troubleshooting or if the issue persist than Replace the Power supply for your product.
Jul 06, 2010 | HP Officejet 4315 All-in-One Printer
I have a brand new HP M1319 unit and I am getting a copy pending message when I try to copy a document, do you know why?
I had the same issue. I just got off the phone with HP tech support and they had me turn off the power, unplug the power cord, wait 10 seconds, then turn the power switch on (with the machine still unplugged) and wait 5 seconds, turn the power switch back to off, and the plug the power cord back in and power up the machine. It fixed my "copy pending" problem, I hope this helps.
Oct 05, 2009 | HP Laserjet M1319F Laser Multifunction...
Turns on but no boot
I had this happen sometimes after a windows update/reboot.
If the computer is on, hold down the power button until it cuts off.
Unplug the power cord. Wait for a couple of minutes.
Plug the cord back in, and turn on system.
Oct 27, 2008 | Acer Aspire T160 (AST160UA3400) PC Desktop
Strange delay.
I'm having the exact same strange delay problem as you.
I fixed my delay when I too took my machine to your girlfriends. LOL!
No seriously.... you solved your delay problem yourself when you UNPLUGGED the power cord from the back of the monitor.
My guess is that when you unplug the power cord, the monitor resets itself. It's only a temporary fix, but, IT WORKS.
1. Turn the monitor OFF
2. Unplug the power cord from the back of the monitor
3. Wait 10-15 seconds or so
4. Plug the power cord back in
5. Turn your monitor ON........DELAY ELIMINATED.
The delay returns eventually, but, I just unplug-n-replug and I'm good to go again.
Apr 07, 2008 | Gateway FPD2275W LCD Monitor
HP LaserJet 4 plus Printer Logo
Seeker5211
Seeker5211
