Question about Black & Decker String Trimmer Cordless 12" 18V
GRASS HOG Cordless/cannot remove the motor housing to check
I have a Black & Decker Cordless "Grass Hog" and it has stopped working, I have checked the Battery...that has volts....and all the wiring but cannot get to the motor to look at that as I cannot remove the bottom covers.....there is a spring loaded handle that allows you to change the angle of the machine so it then acts as an edge trimmer....any ideas....Thanks
  • 9 Answers
SOURCE: Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Posted on Jul 30, 2008
Hightower971
  • 183 Answers
SOURCE: auto feed will not work
It's cheapest to buy a new one. I had that problem last year.
Posted on Apr 28, 2009
darth yoda
  • 4 Answers
SOURCE: Motor runs but base doesn't spin to do the trimming. How can I fix this? I have a Black & Decker 14 inch Grass hog- electric trimmer.
gearbox!! get rid of it
Posted on May 29, 2009
  • 133 Answers
SOURCE: how to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Posted on Apr 21, 2010
Parts for Black & Decker 14" Grass Hog Xp Trimmer/Edger
Easily, the best place and discounted parts place for this Black and Decker trimmer is eReplacementParts.com
Oct 06, 2010 | Black & Decker 14" Grass Hog Xp...
What replacement line is used for the BLACK & DECKER Grasshog. 5,063,673 5,620,336 6,443,753 6,443,762
For the cordless Grass Hog, the replacement spool is AF-100. You can purchase these spool heads online or maybe find them at your local hardware store, but they may be hard to find because the Grass Hog is not made any more.
Jul 13, 2010 | Black & Decker 14" Grass Hog Xp...
I just bought a BD Grass Hog and after 1 h of use,
If the noise was up by the handle it may have been the drive pulley breaking loose of the shaft on the motor causing the motor to spin and stop the flex shaft of the trimmer. Another possibility would be the small belt that aids the flex shaft. If those don't fix the problem check the lock nut that bolts the flex shaft to the spool housing. If the shaft broke free from the housing the motor would still run and the shaft would turn, but the spool housing would not spin if it does it could be stopped very easily. Definately check the warranty.
Jul 07, 2010 | Black & Decker String Trimmer Cordless 12"...
How to restring back and decker grass hog
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
String will not advance on black and decker grass hog electric trimmer
Did you re-string it? If you did it is possible that you crossed the string over itself and it is stuck. Check that and good luck...Lee
Oct 20, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Describe your Black & Decker
You can order these thru black and decker at blackand decker.com
Sep 12, 2009 | Black & Decker 14" Grass Hog Xp...
Head of trimmer/edger doesn't spin
i have the same problem, the plastic timing pulley on the motor assembly is probably melted, remove all the screws down the side of the housing, including the one hidden under the label, and you will find that the belt and the pulley are both chewed up.
Apr 18, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker String Trimmer Cordless 12" 18V Logo
113 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
