Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Admiral - GC2224GEKB
The freezer section of our side by side is not working. The fridge is working fine, the lights come on in the freezer, and we have reset by turning off for 30seconds. Any suggestions?
  • 6 more comments
  • bokke Oct 25, 2007
    Actually has turned out to be both the fridge and freezer section that has blown - (lights + fan seem to go but no cooling). When I phoned the manufacturer they said it could be anything and that we would need an engineer. Since it is just over a year old (20days) we have to pay a whopping £120 for the call plus whatever parts are required! Needless to say I am pretty disappointed with Admiral/Maytag.
  • bokke Oct 26, 2007
    An engineer came round yesterday, and it turns out that as we open the doors, the fridge lights turn on, and shorts the compressor. Resolution is replace theswitches.
    Thanks for all your input.
  • Anonymous Mar 25, 2008
    My Admiral has stopped working intermittently for the last few weeks ie it stops for about 24 hours everything defrosts and gets ruined than it just starts again for a week or so and the same thing happens. We got someone out last week, they replaced the control board and charged £150. The next day the fridge went off again and has not come back on. The old board was jazz9 and the new one jazz10.
    Any help would be appreciated
    Graham
  • Fredup Mar 25, 2008
    yup... ours is just the same... open the doors and you can hear the fan etc cut in... what did he replace??
  • tonytumble Mar 25, 2008
    yup my Admiral duo- AC2224GEKB has been on/r a while now it just seems its given up even tryin to cool... one thing i noticed from another thread is that when the door is open the fan kicks in , and stops when you close it again...!! is this the problem as with the condeser short / light switch thread?? opr do they do that? the unit is prob 18 months old... will any refridgeration engineer be able to fix??
  • coldcustomer May 02, 2008
    any luck with repair?
  • Anonymous Mar 10, 2009
    help, our fridge is so cold and does not turn down!!!!!!!
    admiral duo
Water dispenser not working correctly AND DISPLAY PENAL NOT PROPERLY RESIT WATER VERY SLOW COME OUT
Posted on Nov 11, 2009
  • Admiral Master
  • 4,655 Answers
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Posted on Oct 25, 2007
  • 1 more comment
  • John Tripp
    John Tripp Oct 25, 2007
    I'm on my way to work as I multi task and will be available again but continue to ask others technicians here while you are there today we do want to help! If compressor is running try to turn defrost control to right in cold food section and listen for the compressor to stop that will indicate defrost timer fault and then need replaced Let us know sorry I have to go for a while and we are all wanting to help you solve this. JT
  • John Tripp
    OK, I'm back and just finished some research. The Refrigerator has a temp control circuit board. It's a GE Refrigerator and the control board list price here in the USA for $66.53 Now The web site has listed numbers wrong above other peoples names like yours showing so many different name/brands and model numbers. I hope yours is correct as not to anger you or make things difficult. So are we are sure your refrigerator is a part# GC2224GEKB ? Because that is listed as a GE part. The circuit board replacement for this( if correct) is WR5510172. Now not to confuse you Admiral may use the same part number..Hope this helps you and makes things go a little easier for you. Let me know as soon as possible if we are on the wrong track, Thanks Sea Breeze
  • John Tripp
I have an admiral gc2224gekb side by side. The ice machine isn't producing ice and also the fridge is freezing up
First, check to see if the airflow is blocked at the back of the fridge compartment as this also may cause the lower items to freeze. Fridge freezing is usually the malfunction of the damper swing door or the circuit controlling it. A failure of the temperature sensor in the fridge could be the cause. We just had ours replaced this year [on extended warranty]
Sep 22, 2016 | Admiral Refrigerators
What bulb do i need for my Admiral fridge freezer model GC2224GEKB?
That sounds like you have a 240 vac light bulb and 240 voltage home service, so you are possibly outside the USA correct? The fresh food compartment calls for two bulbs model=> 67002552 40w-250v Light Bulb
You may also get these from=> Repair Clinic
The freezer compartment also uses one of the same bulbs=> OEM # 67002552
If you should have any questions please let me know and please rate my solution, Thanks, Sea Breeze
Mar 08, 2011 | Refrigerators
Hi i have a fridge freezer model no GC2224GEKB,i have noticed that the refrigeration side has started to freeze even though i have it set to 3oc.
I just answered the same question so I've copied you into it hope you don't mind.
A common problem to this is the damper (vent from freezer) is bad or just stuck open, try defrosting it and adjusting the position so that you reduce the amount of cold air going into the fridge, hopefully it'll just be stuck in the open position and you well have no further problems. Always here to help.. Richard.
Jan 19, 2011 | Maytag Admiral Top-Freezer Refrigerator
I have an admiral GC2224GEKB
You may have to open the door to let the dispenser thaw since it's in the door.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 03, 2009 | Refrigerators
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
My fridge freezer has stop working but if you open the door it start to work but if you shut door it stop's and you can hear the fan in freezer stop and start it's a admiral gc2224gekb side by side
Hi thanks for te question. it should be the opposite of what its doing did somebody work on this fridge before. it looks like somebody switched the light and the fan switch
Oct 07, 2008 | Admiral Refrigerators
Fridge making loud snapping noises
we have much the same problem except ours was going on for some hours at a time and then off for short periods. contacted Comet engineer who says its the compressor and will cost almost as much as a new machine to fix it. we are disgusted as its only just over a year old and has been repaired twice already. we would also add that both
the fridge and freezer are now completely out of action and have been all over the Easter period which has caused us much inconvenience. we will take this matter further if no satisfaction is gained from Comet.
Feb 28, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
1,657 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
