Question about AOpen Computers & Internet
Aopen motherboard front connections
I have an Aopen i945gm-pilf motherboard. I need the digram for the front usb and audio connections. It only came with power, reset and etc. connections.
  • 4 more comments
  • mkiefer Jun 11, 2009
    Sorry, but I do not see any solution. All I see is the words "here are the connector and their pin out" nothing else no links or others words of description or diagram.
    These links must not be Mac compatible. I will have to find a windows PC to check them out.
    I am using Firefox and on both the mac and windows computer. When I click on the links it says that this page can not be found and there is an error of a 404.
    Ok, it is mkiefer@btussel.com. And for the pictures i can see your picture and many others on the page. You should be a white male with dark hair.
  • mkiefer Jun 12, 2009
    I received the email with the jpegs. The usb ports work but I have no way at this time to test front audio, The case connection state it has something different than the way it states on jpeg. so I will have to leave at it is.
    Basically it was fine.
  • AOpen Master
  • 13,433 Answers
Here are the connector and their pin out
Posted on Jun 05, 2009
Aopen i945gm pilf motherboard manual
Hello you cam download the manual here:
http://europe.aopen.com/download.aspx
By selecting mainboard and the model number.
Good luck
Apr 11, 2013 | AOpen Computers & Internet
MX46-633V CONNECTING FRONT USB
I believe you're referring to the AOpen MX46-533V
The Front Panel USB header is Blue in color, and located in-between the white No.3 PCI expansion slot, and bottom edge of the motherboard;
http://www.ebay.com/itm/AOpen-Model-MX46-533V-Socket-478-Desktop-System-Motherboard-/130774572519?pt=Motherboards&hash=item1e72c59de7
With the motherboard in the installed position;
5 pins across the Top row, 4 pins across the Bottom row.
Pins across the Top row are numbered EVEN
Pins across the Bottom row are numbered ODD
Starting on the Left side coming across to the Right, Top row;
Pins 2, 4, 6, 8, and 10
Bottom row;
Pins 1, 3, 5, and 7
There are TWO USB connectors supported off of this USB front panel header.
For one of the USB front panel connectors;
A) Pin 1 is USB PWR 0
Goes to the VCC contact pin on the USB connector.
B) Pin 3 is USB_FP_P0-
Goes to the D- pin on the USB connector.
(Data - )
C) Pin 5 is USB_FP_P0+
Goes to the D+ pin on the USB connector
(Data +)
D) Pin 7 is Ground (GND)
Goes to the Ground (GND) pin on the USB connector
E) No pin 9
F) Pin 2 is USB PWR 0
For the other Front Panel USB connector;
A) Pin 2 is USB PWR 0
Goes to the VCC pin on the USB connector
B) Pin 4 is USB_FP_P1-
C) Pin 6 is USB FP P1+
D) Pin 8 is GND
E) Pin 8 is USB_FP_OC0
Leave unconnected
This is more information on a standard USB connector pinout,
http://en.wikipedia.org/wiki/USB
( A USB connector, and a USB plug are not wired the same.
The plug is wired backwards from what a connector is.
Otherwise you would have power and signal going to the wrong pins, and burn the USB Front Panel header out on the motherboard )
AOpen MX46-533V motherboard manual, but it is in Japanese.
May be one in English out there.
The Front Panel header pinout, USB header pinout, etc, is easily cross identified,
http://global.aopen.com/products_download.aspx?sDropDownProd=52
Manual / Japanese manual for MX46533V / Japanese / 1/28/2006
Go to the far right, and click on the Floppy Drive icon above -
3701.1 KB
On the next page click on the mirror server website that is closest to your country.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country server name it may take up to 30 seconds, before the first page comes up.
(File is downloading in background)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 19, 2012 | ASUS P5PE-VM Motherboard
Where can i download the sound driver for my AOpen AX34 PRO motherboard?
You can find the audio driver on the manufacturers website using the following link.
http://usa.aopen.com/userdownload_List.aspx?RecNo=4018&Model=147
Hope this helps.
Aug 20, 2011 | AOpen AX34 Pro (91.88910.101) Motherboard
After installing the os audio driver is not showing in device manager
You need to install the AOpen motherboard device drivers which include the audio driver. Click on this link and select your model motherboard to download :-
http://download.aopen.com.tw/
Feb 13, 2011 | AOpen Motherboards: MX4GVR-GN (AMX4GVRGN)
Onboard audio out not working, pluged in audio board just crekeling musik can be heard just noise??? Thanks Joe
try to use front audio ...maybe rear audio socket was damaged...
some motherboard has connection 9pins, you can connect you front audio into it..
May 24, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Cwss4joe@msn.com asks Does the AOpen MX34-U
Yes it has onboard audio.
Here is a manual link:
ftp://ftp.aopen.nl/pub/manual/mb/mx34u/mx34u-ol-e.pdf
You can go to the Aopen sit eto download the driver if it is not working.
Go to http://usa.aopen.com/download.aspx and Select Motherboards in the drop down Product Selector. Then select your MB model #. Then select the category...if you need the Audio driver, select Driver. (Manual, Bios, etc.)
Thanks for using Fixya.
Wayne
(Note: The manual link is from Netherlands. Had trouble with US site.)
Jul 11, 2009 | AOpen MX34 (91.88510.101) Motherboard
Don't know where to plug in cabels
Here is a link for the User Guide for the AX4BS mobo.
AX4BS User Guide
Check out page 15. That should give you the info you need.
Nov 26, 2008 | AOpen AX4BS (91.32Q10.002) Motherboard
Aopen ax4bs no audio device found.
I've tried this and your right. It is the Jumper Caps missing causing your audio not to work. It should work. Maybe your diagram is up side down? Or maybe it is the wrong jumpers?
Oct 24, 2008 | Acer AOpen AX4BS-V (91.89J11.001)...
P4mmv2 motherboard
see the diagram below for front panel conections
Sep 02, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
334 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
