Question about Tiny Computers B1996 19" CRT Monitor
Monitor - no signal
After storing my computer and monitor for 3 months, which both worked perfectly, now when i've set it all up again , the monitor says .no signal.then goes blank,,,,,ive tried 2 different working monitors with the computer. same problem. checked all cables.still nothing. can anybody help please.
Eve
  • 53 Answers
It doesn't seem to be a monitor problem but a computer problem, is this a desktop or a laptop ? see if you can re-sit the display adapters.
Posted on Jun 03, 2009
Samsung Syncmaster 2333
Check signal cables means there's no signal on input. If your PC still shows up on a different monitor then it's a time to replace a mainboard in your monitor.
Jun 03, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
My monitor keeps saying "no signal". I confirmed
No Signal on your monitor says it is not receiving a signal from your computer... this could be:
1) the cable is bad
2) the cable is not plugged in firmly
3) your monitor is set to a different source (such as VGA or HDMI) and simply needs to have the option set.
4) the video card or onboard video electronics have failed.
Suggestion: If none of the above seem to be the problem, and if your computer AND the monitor have a VGA connector AND you have a VGA cable. Try that. If that works, its a strong indication that the DVI circuits have failed either in your monitor or in the computer's video electronics.
Aug 28, 2017 | Envision 19" Widescreen Flat Panel TFT LCD...
When I took out my digital camera and mic, and then closed my computer. After 3 hours later, When I started the computer, it lead me to a screen where a box that says Check Signal Cable. It has all 3...
hi,
the check signal cable is coming from an issue about your monitor and computer. socheck that cable and the monitor may have multiple inputs but should auto detect the connection when turned off and then on again.
I would recommend you disconnect all things but a mouse and keyboard. then turn on your system and get this fixed first once the machine works again plug in your devices as you want them and your all set.
hope this helps
GL
don't forget to vote for me
thanks
Jammer
Jul 01, 2011 | Computers & Internet
I got this monitor off of craigslist "because it didn't work". The VGA has never worked, but the DVI worked fine for several months. Recently, the screen goes black, the screen shows a 'no...
Check the VGA output pins on your computer. Install a different monitor and see if it works on your computer. Or it could also be the VGA cable (pins) on the monitor is loose.
Dec 16, 2010 | Neovo E-19A 19" LCD Monitor
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
No signal detected
change the CRT/LCD to Presentation. this is done on a Dell (for example) by pressing the blue Fn key and the F8 key which cycles thru the three modes: off, shared or on. bit late (may 2009)0 but just in case/
Mar 17, 2009 | BenQ G2400W Monitor
Dell m992 crt monitor
If it's getting no signal, make sure the monitor is set for the correct input. This would be either analog (if your cord has blue ends) or digital (if the connectors are white). Depending on wt yhat your monitor is, a button on the monitor will help you set that. If it's set for the correct input signal, then switch out a different cable to see if perchance you have a bad cable out of the box. If there is another PC or laptop setting around, plug your monitor into that to make sure it's good and maybe even plug THAT monitor into yours to make sure there is nothing wrong with your video card. Let me know what transpires. If this takes care of things, please help me out by rating it accordingly.
Jan 13, 2009 | Dell M992 19" CRT Monitor
No Input Signal
Dont Panic it is Nothing...
Your Monitor is safe...
If it say "no Input signal" - "Check VGA cable"
it means that the Monitor is finding signals from the computer,and the cable is either not connected or unsecurely connected.
Jul 18, 2008 | Chi Mei Corporation 221A Monitor
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
Tiny Computers B1996 19" CRT Monitor Logo
103 people viewed this question
Top Tiny Computers Computers & Internet Experts
David Payne
David Payne
Are you a Tiny Computers Computer and Internet Expert? Answer questions, earn points and help others
