Question about Crosley CDE6000 Electric Dryer
How to replace the drum drive belt
Drive belt broke, but I do not see any easy access to replace it.
The front of the machine comes off pretty easy this will give you access. Open the top by pulling up in the front of the dryer inside you will see two screws going in to the front panal remove them and the front comes off. Watch the wires to the door switch
Posted on Jul 14, 2009
I have an eziloader 6kg dryer, the drum does not spin but the heater element turns on. How do I check if the belt has come off?
can you turn the drum reasonably easy whilst the machine is empty and off . If you can than the drum has no load and the belt is either broken or has come off the drive pulley or the drum . Disconect power cord from socket and remove back off machine ..You know should be able to access drive belt and either replace belt onto drum and drive motor or purchase and fit new belt . It is a good idea to replace a belt that has slipped off and is not broken - belts stretch and its likely to come off again . If this is one with a sealed back then turn it on side and remove base to reach belt .
Aug 13, 2011 | Dryers
My dryer turns on but does not turn the tumbler AROUND
Check belt & belt tensioner. Belt could be broken or tensioner spring broke releaving tension around motor pulley. You can do this by removing access panel on back of dryer, make sure you UNPLUG dryer before you do anything. Broken belt requires removing front drum end, not so easy, but do-able
Feb 13, 2011 | Maytag Dryers
Drum wont turn. Motor and blower run.
sounds like you broke a drive belt, remove the dryer shell and you should find the broken belt pretty easily you can also replace it yourself it is a relatively easy job......HAVE FUN ........YOU CAN DO IT!!!
Nov 30, 2010 | Dryers
HOW DO I CHANGE THE BELT ON A WHITE KNIGHT CL447WV - DO I REMOVE ALL OF THE SCREWS ON THE BACK + IS THERE AN EASY WAY TO GET THE BELT ON?
You must pop off the top of the dryer then remove the front after the front is off you can get to the drum. The belt goes around the drum and the motor pulley and under the tensor wheel after you get belt on replace front and top since you do have the back apart you can do it this way:
Remove the back -lots of screws- to allow access the drum. Then tip the machine on its face and unscrew the access panel that lets you get to the drive wheel. After feeding the belt around the drum from the top, reach into the access panel and pulled the belt over the pulley wheel
Which is easiest, the choice is yours as they are about the same either way. Hope this helped Tim
Nov 27, 2010 | Dryers
How to replace the belt that it broke
To replace a belt on a Frigidaire front loader, follow these steps:
1. Unplug the washer and turn the washing machine around so you can access the back panel. Remove the rear panel by locating and loosening the screws around the perimeter of the panel.
2. Loop the drive belt on the drive motor pulley with the ribbed side on the pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the drum pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, or are uncertain if these steps let me know. I hope this information is helpful.
Nov 28, 2009 | Frigidaire FWS1339A Top Load Washer
How to fit new drive belt to white knight tumble dryer
YOU HAVE TO REMOVE BACK AND EASE REARWARD - THEN SLIP DRUM BELT IN FRONT OF DRUM THEN REASSEMBLE - NOT EASY TO EXPLAIN
Apr 05, 2009 | Dryers
Roper Dryer won't spin.
From what I understand, it sounds like the idler "pulley" is broken. Upon receiving power to the motor, the belt inter-connects and ultimately drives and rotates the pulley and drum. The pulley is designed to guide and give "tension" to the belt when connected to enable the drum to "rotate and tumble".
The pulley is relatively simple to replace and can be purchased from your local appliance dealer for about $10 - $15. Depending on your "handy" skills, I would take the following steps to check your belt and pulley;
1. Disconnect the Dryer
2. Access the dryer cabinet/pulley by removing the front door (If your pull and clean fileter from top, remove 2 screws near filter. You may need a putty type knife to "slide and pop" the dryer open)
3. You may see the dryer belt already broken or disconnected, but take a look at the pulley and check for broken wheel, metal, chips/cracks, etc. Sometimes you may need to replace the pulley all together, but you may only need to replace the wheel part depending on the model of your dryer.
-Maintuniverse
Feb 01, 2009 | Roper RGX4634KQ Gas Dryer
Drum does not rotate
The drum rotates due to a belt that goes around the drum and is driven by a small motor. The most likely answer is that the belt broke. This a common problem on an older dryer. It is relatively easy to replace the belt.
Feb 01, 2009 | Kenmore 62602 Electric Dryer
My dryer drum stopped turning. The dryer will turn on
it does sound like the belt is broken. you will need to access the inside of the dryer by removing the front. they all come apart differently. Make and Model would help me tell you more.
Dec 26, 2008 | Dryers
I have a kenmore series 80 dryer model 110-70812990 that i heard a bang then the drum stopped turning and i smelled burning rubber. I'm guessing that the drive belt broke. How easy would that be to repair...
Remove back of drier after disconnecting the power cord. Find old belt laying on floor under machine. Obtain new belt and place around drum and motor pulley. done
Crosley CDE6000 Electric Dryer Logo
131 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
