Question about Lexmark X1240 All-In-One InkJet Printer
Install Ink Cartridge
How do I install the ink cartridge in my new Lexmark X2450? - no instructions came with it.  Can't get to the original cartridge.
  • Melville Oct 24, 2007
    The above is not helpful as the cartridge is so far to the left of the printer and it does not move into a position where I can replace it.  Not sure if this is a fault on this particular printer or if my printer is playing up.
    Thank you for trying.
  • Anonymous Feb 08, 2008
    how to remove and replace cartridge
    Novelist:
    Scholar:
  • 167 Answers
Swith on the printer. Open the printer top cover. It is called flap. Now press upwards the cartridge's top end. and lift up that. now take the cartridge out. insert the new cartridge the same way took the cartridge out. put the cartridge layer down. Now close top cover.
Posted on Oct 24, 2007
  • Deepu Amalan
    Deepu Amalan Oct 25, 2007
    Lexmark X2450 is a multifunction printer (MFP).
    It is a difficult problem for me to figure out how to help you, but still just give a try.
    You should have installed the printer utilities from the CD that came with the printer.
    Open that utility > Find something similar to "change cartriges"...   hope this could do some help.
  • Deepu Amalan
    Most of the latest printers have this utility with in the CD. if you have not already installed it. You can do it now. if the CD is missing you can download it from the manufacturer's website.
I refilled my Lexmark cartridge but it continues to say I need to install a new cartridge. The printer model is x2670.
Hello there,
The reason why your Lexmark printer keeps on telling you to install new cartridge because the printer have ink cartridge detection. Meaning it will detect whether that particular cartridge is an old one or not.
Each Ink Cartridges have its code and it will be registered to the printer once you have connected it. The printer will assume the ink level and once it is empty, that particular Lexmark Ink Cartridge will be registered to your printer as an empty ink cartridge and needed to be replace with a new one.
I would suggest getting a genuine new cartridge instead of refilling the ink cartridges.
Feb 17, 2011 | Lexmark X2670 All-In-One Printer
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
How to install a new ink cartridge in Lexmark 2350 printer/scanner
Perhaps the Lexmark X2350 User's Guide will be able to help you. Just click on this link to download: http://bit.ly/bNOTdZ. Scroll to Replacing the print cartridge, Page 52, for the instructions on how to install your new ink cartridge.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Sep 15, 2010 | Lexmark X2350 All-In-One InkJet Printer
Can't reset ink level on my z605 lexmark printer
Go to "Lexmark solution center", then go to maintenance, then "install new cartridges".Check "No, this is new" option on cartridges and ink level will reset.
Oct 30, 2009 | Lexmark JetPrinter Z605 Color InkJet...
Lexmark printer always want a new cartridge
What you need is to reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
May 28, 2009 | Lexmark X2500 All-In-One Printer
Hope this help.
YBC (/\)
Feb 18, 2009 | Lexmark X2500 All-In-One Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
Maybe you can try to rest the black ink level 1st. To reset the ink level:
Hope this help.
YBC (/\)
Jan 14, 2009 | Lexmark X2500 All-In-One Printer
Indicates incorrect ink levels
i want = Driver Printer Lexmark z615
Nov 17, 2008 | Lexmark Z615 InkJet Printer
How do I install an ink cartridge in a lexmark x2330?
if you go to there site it will tell you how to do it
Nov 10, 2008 | Lexmark X2330 Printer
How do I change the ink cartridge in my Lexmark x2470
How to Install or Replace the Ink Cartridges in the Lexmark i3 ID: 810 This document does not apply directly to your Lexmark X2470
  1. Make sure that plain paper is loaded in the paper tray.
  2. Ensure that the power light is on.
  3. Open the cartridge door.
    The cartridge carrier may move slightly, and then return to the loading position.
  4. Push up on the cartridge lever.The cartridge holder springs open.
  5. Remove the old print cartridge and dispose of it.
  6. Remove the sticker and transparent tape from the new print cartridge.
    Warning! Do not touch the gold contact area on the print cartridge.
  7. Install the new print cartridge as illustrated below. Insert the cartridge into the carrier slot. Push the cartridge lever back to secure it under the cartridge hook. Press the cartridge lever down until it snaps into place.
    Insert the color cartridge in the front carrier slot.
    Insert the black cartridge in the back carrier slot.
  8. Close the cartridge door.
  9. On the PC, open the Lexmark i3 Solution Center and click Print Cartridges.
  10. Then click Print Cartridge Installation and follow the on-screen instructions to install the cartridges.
Please Rate the solution.
All the Best
Sammy
Sep 26, 2008 | Lexmark Office Equipment & Supplies
Lexmark X1240 All-In-One InkJet Printer Logo
221 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
