Question about IBM ThinkPad R50e Notebook
Faint transparent band to right of 17" screen on toshiba sat. lap
This faint white or light gray band just appeared on the right most 2 inches of wide screen monitor on my toshiba satellite laptop. I didn't bang it or anything. Laptop is 4 years old, I can still use it, but would like to lose the band if possible.
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Inspiron 5160 screen has a negative appearance and a 2" wide white vertical band on the right side. What could cause this?
Are you sure someone hasn't sat on or dropped it, sorry I don't mean to be pessimistic but it doesn't sound good. John
Jul 19, 2010 | Dell Inspiron 5160 Notebook
Have a gray transparent band on right side of screen
do you ever run dual displays using a monitor?if so,is the gray band on that screen too?if you grab the screen at the top and flex it left or right does the image change,if it does,check your display connection to the graphics card on the motherboard,and inspect the ribbon for signs of damage,if the same image is on a monitor in dual display,it may be a software problem uninstall your display adapter and all monitors in device manager,,and any software related to it ,restart and when it automatically finds new hardware,cancel it,go to the ibm support site get the latest bios update flash it exactly as the instructions state,,download fresh graphics driver and reinstall,hope this helps aloha from maui todd0708
Sep 02, 2009 | IBM ThinkPad R50e Notebook
Stripes appear on monitor at bootup
I decided to change the background of my desktop and it works.
May 14, 2009 | Gateway FPD1760 17" LCD Monitor
Toshiba 3550 Copier - Printing a faint ''gray'' band over text
Depending on how many copies you have run, the drum as well as the cleaning blade needs to be replaced.  That should get rid of the gray band.
Nov 11, 2008 | Gestetner DSc224 Copier
Grey transparent vertical band centre of screen
enter the bios nad set the keyboard option to unlock
Oct 23, 2008 | IBM ThinkPad R50e Notebook
Grey transparent vertical band on laptop screen
This problem occurs due power fluctuations and over heat .You have to change the laptop screen .No other way to go..
Good Luck
Siju.D
IBM ThinkPad R50e Notebook Logo
129 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
