Question about Home
Shower boils after iturn down water - Home
  • Fred May 11, 2010
    I need more info. What do you mean the shower boils? What do you mean turn down the water?
  • 146 Answers
Well if a single handle then you replace the valve
Posted on Jun 26, 2009
Overheat light won't turn off, strange boiling sound.
it may have calcium build up in the valving.. may need to run some chemical thru it..
Jan 25, 2014 | Home
Water leak thru valve when turn to shower
a lot of shower diverters do this..you may need a bigger seal on the diverter..if you can remove the spout assembly from the tub(with the diverter valve in it) and take it all to the hardware store.. see if they have a different seal/diverter that has a snugger fit but still falls to drain the shower head line out..that will slow that leakage..the spout is on a pipe and unscrews counter clockwise(normally)unless its a single valve unit..with the wide ring around the back..then that calls for a plumber..
Jan 21, 2014 | Moen & Bayhill& Single Handle Tub & Shower...
Greenstar 30cdi no hot water
It is the shower head or plumbing that has a built in mixer or reducer.
Dec 09, 2013 | Stiebel Eltron CK20E Electric Tankless...
Greenstar 30cdi hot water issue
The problem is not the water heater. The shower has a mixer or a limiter built into the plumbing so that the water wont get hot. It is a safety feature to prevent burns and protect children from scalding.
Dec 09, 2013 | Water Heaters
Gainsbourgh stanza 9.5 shower is boiling and water running slowly
it could be your shower is full of lime scale if it an electric shower if so try turning off the power and take the shower front off remove the heater chamber and block off the out let pipe and pour in a kettle descaler and wait this should remove scale then rince and put back together checking for leaks .
Jan 30, 2013 | Home
Water stains
vinegar solution, then rinse in the hottest water you can find...its the same water deposits you find in your shower. If its not bad, we used to put boiling water into a small glass, and then set the other one upside down on it...would allow us to polish for restaurant service.
Aug 20, 2012 | Home
I have a new delta single handle only shower and i have little or no water i have good preasure when i take out the insert but none when it is installed?
Shower is clogged. Put some caustic soda in boiling water and place the shower in it for some time. clean the inner side with some iron rod & retry
Aug 13, 2010 | Delta & Single Handle Shower Faucet
Shower goes boiling hot then freezing
does this happen with any other fixture in your house that almost sounds like an element in a hot water heater.
or remove handle and look for an adjustment dial to temper water and adjust it
Apr 30, 2010 | Home
After shower i turned of the water and a few seconds later boiling water dribbled from the shower head-that is when the thermal overload cut out
If you have a water heater.
The temperature is set too high. The water is expanding in the system and will leak out at valves. Your safety relief valve should discharge before this happens, after you adj. the temp i would check this.
Jun 05, 2009 | Home
Home Logo
42 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
