Question about Maytag Neptune MDE5500AY Electric Dryer
THE DRYER IS MAKING A NOISE ON THE LEFT SIDE WHEN IT IS ON
THERE IS WHAT SOUNDS LIKE A BANGING NOISE WHEN THE DRYER IS ON. THIS SOUNDS IS COMING FROM THE UPPER LEFT SIDE
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
uio4
Posted on Sep 29, 2010
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
Drum is making some really nasty banging then screaching sounds when entering high spin - any ideas??
sounds like main drum bearings not common but if the bearings are worn you get the banging noise and as it slackens the drive belt you get screeching noise as the belt slips.
Nov 21, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Maytag neptune dryer making banging noise on each rotation on the left side facing the front. its almost like a thumping noise what do i need to do please?
The drum baffle screw has unscrewed itself and the head is thumping against the inside top panel. Pull door, lift lid, rotate drum to find screw sticking out and tighten.
Aug 03, 2010 | Maytag MDE5500AYW Electric Dryer
Dryer is making a banging noise? Sounds like
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 17, 2010 | Maytag MDE9700AYM Electric Dryer
Our dryer has started making a loud thumping sound and smells like rubber burning?
It sounds like you your dryer may have a bad Blower Wheel, which is causing the banging noise that you are hearing (especially if the banging noise continues for a few sections after you turn your dryer off).
Hope this is helpful.
Jan 16, 2010 | Microsoft Windows XP Home Edition
My dryer is making a loud banging noise on the left side of sounds like something is rubbing in it. Any idea what it might be, and how to fix it?
heatman101
76fg
Jun 24, 2009 | Maytag Neptune MDE4000 Electric Dryer
Banging noise as dryer spins, wore hole in side of dryer
I need to know your make and model number in order to give proper advice. Joe
Nov 07, 2008 | Maytag Neptune MDE5500AY Electric Dryer
White knight tumble dryer making banging noises when spinning
I have this banging problem, it sounds like a plastic ball rolling about inside it
Aug 25, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
182 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
