Question about Kenmore 21.9 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Took gear off need to know how to time ice maker . kenmore side by side
    Sergeant:
    Champion:
  • 291 Answers
Replace the icemaker module
http://www.repairclinic.com/SSPartDetail.aspx?s=b6a4i1469018&PartID=1469018
Posted on Jun 03, 2009
We have the Kenmore 106.5703.601 side by side with an ice maker. We lost power for a whole day. The power is back, but the ice maker does not dispense ice. Water is dispensed through the door fine, and...
I think if you unplug the ice maker and remove it from the freezer to let the ice melt and dry out the Ice maker may start working again once you put it back in the refrigerator. If not we will need to check the thermostat inside the ice maker. Try that first and let me know the results. We will get it working I just need you to do this step by step until I locate the problem. But until the ice maker is dried out I cannot see if the thermostat will call for water when plugged back in. Let me know, Sea Breeze
Aug 16, 2009 | Kenmore Refrigerators
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore side by side makes no ice
the water line coming into the freezer may be iced up. or the motor that spins the ice "ejector" arm may be stuck. try spinning it manually (just dont force it).
May 29, 2009 | Kenmore 44103 Side by Side Refrigerator
Kenmore ice maker wont dispense ice. Makes ice OK but wont dispen
THis happened to mine last year. The part you need is #628366 Motor - Module. Sorry That is what i had to do, but i had to pay a repair man to find the problem. Hope this helps.
Jan 24, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice maker # S10626636 water level adjustment
IF THE ICE MAKER IS OVERFLOWING, THE ADJUSTMENT SCREW WON'T HELP. ON MODULAR ICE MAKERS, THE BIG
WHITE GEAR ON THE FRONT BEHIND THE COVER HAS CIRCUIT TRACES ON ITS BACKSIDE THAT WILL ARC, BURNING THE PLASTIC GEAR, BRIDGING THE FILL CIRCUIT WITH ANOTHER TRACE, MORE THAN DOUBLING THE FILL TIME. THE MODULE NEEDS TO BE REPLACED. (GEAR IS NOT AVAILABLE BY ITSELF).THE MODULE IS THE SQUARE PLASTIC ASSEMBLY MOUNTED TO THE FRONT OF THE ICE MAKER WITH THREE SCREWS. INCLUDES THE MOTOR.
Mar 27, 2008 | Kenmore 53552 / 53554 / 53559
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side ice maker
There are as you can imagine many possible causes for you no ice condition. I will give you the most common problem for the year model you have. I hope this helps you.
You will need to remove the ice maker from the freezer compartment to check it. Once it is repaired if the following information does help, and you reinstall the ice maker, it should go through a cycle automatically within an hour of your reinstalling it in the freezer compartment.
Once you have the ice maker out of the freezer compartment you will need to remove the white cover on the end of the ice maker and look at the center of the large white gear. If the part inside the hole in the center of the gear is broken or looks twisted, you will need to replaced the module. The module is the part that has the large white gear and is held in the ice maker by 3 phillips head screws. It only comes as an assembly. You can't get just the little broken piece.
supertechks
Please don't forget to rate me
Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Sep 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Icemaker slow to make ice
Tener, sounds like you have a module going bad. Pull off the white cover of the ice maker and take a look at the center white gear. There should be two clips securing the gear on. A lot of times these clips break and cause the gear not to rotate properly. Part number for the module is 628399. Take a look at this first. Catriver..post back
Nov 01, 2006 | Kenmore 53202 / 53204 / 53209 Side by Side...
Refrigerators Logo
80 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
