Question about Kenmore 22932 Top Load Washer
The washer will not go in to the final spin cycle. It is a Kenmore Elite Total Care System top loading washer. Model #23032101, Serial # CM4928725, Type: 111 10 amp, 120 v. After I open the lid when the cycle is complete the clothes are in the bottom of the tub and still sopping wet
  • 2 more comments
  • Steve Young Jun 04, 2009
    Hi Greg,
    Thanks for the answer. I can probably run down the timer. My question is: how difficult is it to change out the timer? About how long does it take.
    Thanks very much,
    Steve
  • Steve Young Jun 05, 2009
    Hi Greg,
    I want to accept your solution but I have one question: How difficult is it to replace the timer and about how much time does it take?
    Thank you very much,
    Steve Young
    Hello LocalWonder,
    I have checked drains, etc. and they are OK. Do you know how difficult it is to replace the timer. Is this something I could do myself. I am fairly handy and have done a little appliance work.
    Thanks,
    Steve
    Thanks so much Blueextc3221! I really appreciate your time and help. The only number I could find on the unit that resembled the 110 number was a "Type: 111" on a tag inside the washer lid. Does this change the whole thing?
    Thanks again,
    Steve Young
  • 15,935 Answers
Very simple to change the timer!!
You can have it done in an hour if you have never worked on a washer!!
2 screws (rear) hold on the control housing,
Pry off the dial indicator... and 2 more scerws hold on the timer to the housing.
Unplug the timer and replace.
CLICK HERE or HERE to see your part. (please verify your washer is 110.23032101)
SEE THIS BLOWOUT DIAGRAM the timer is #19
If this is not your washer please reply using the "Continue With This Expert" option so we are connected in the future.
Thanks :D
Posted on Jun 05, 2009
  • 6,784 Answers
Hi. this may be a drainage issue here. I recommend checking the following before you replace the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
OK, if all the above checks out OK, replace the timer.
  • 1,959 Answers
Seems this is a common problem with Kenmore/Whirlpool later model washers (Whirlpool manufactures Kenmore Elite) . The most common culprit in washers not spinning out is a faulty timer. It seems that the timer will properly advance through the wash and rinse cycles but is quitting when it gets to the spin cycle.
Other customers have had motors, clutches, wiring replaced, only to find out it was the timer all along. I tried to look up the exact part number but the model number you supplied isn't listed. I hope this answers your question. Best of luck.
Greg
Posted on Jun 03, 2009
Can not restart the Kenmore Elite Total Care Washer
What is the model number of your unit?
Nov 07, 2012 | Washing Machines
My Kenmore Elite total care system gets stuck on the Pause Cool Down step and then again on the spin setting. It doesn't even drain after rinsing.
The washer has a temp sensor for the rinse cycle , so just set the temp to warm water and it will stop getting stuck, because it wants the water to be warm when it rinsing ,ok hope that helps you! Ericc
Jul 03, 2010 | Kenmore 24032\24036 Top Load Washer
Need age of my washer machine
Kenmore elite model number 22054100 serial number CL210158. How old is this washer?
Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Noise during spin after changing clutch / kenmore elite washer
The clutch is likely failed again - or the coupling this time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Energy Eco care system won't spin at all
Kenmore ECO Care system front load washer final spinal cycle
won't shut off. Machine shakes violently.
Feb 24, 2009 | Maytag PAV2300 Top Load Washer
Kenmore Washer timer dial is not advancing
ok " timer has a small stepper motor in it, and it can be replaced
take stepper motor out .
appliance parts store will have it
or just replace timer
take make and model number with you
Jan 13, 2008 | Washing Machines
Kenmore 22932 Top Load Washer Logo
131 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
