Question about RIM BlackBerry Curve 8310 Smartphone
My Blackberry has suddenly stopped working. When
My Blackberry has suddenly stopped working. When people call the line becomes increasingly crackly and then the phone cuts out. I can text fine, tho I sometimes find it has switched itself off. Any suggestions?
  • 407 Answers
I would do a soft reset holding down Left Alt, Right Shift and Delete keys - simultaneously for a couple of seconds. That should clear anything that may be causing a memory issue...
Switching itself off... The above reset should resolve this, or show a bigger issue...
Crackling line though suggests a little more... Is this intermittent or on all calls?
Posted on Jun 03, 2009
My bold has a white screen with a couple black lines going vertically and a black circle/blob in the top right. The phone was never dropped and has no crack in the screen. Please try and help restore to...
You don't have to drop your phone to crack / break the screen. This problem is almost certainly caused by a crack screen. This can be easily repaired by taking your phone to the local repair shop and getting the LCD replaced.
Depending on where you live and who you know you can get this done for $50 - $100 in North America.
Oct 12, 2010 | RIM BlackBerry Bold 9700 Smartphone
I have a blackberry 8900 my calendar alarms do not work they stopped all of a sudden how can I get it to work again?
Hey buddy,
Its simple. Find the Phone settings from menu then select " Factory default setting or restore "
it will work in a second.
Cheers
REgards
MArshal
Dhaka, Bangladesh
bdman2010@hotmail.com
May 20, 2010 | RIM BlackBerry Pearl 8100
I have a verizon blackberry storm 9530, it suddenl...
i'm sorry the only solution is ask for ZAIN to un suspend your blackberry pin becouse 9530 work's in 2 network so it has 1 pin for cdma and gsm it's impossible to crack it
May 19, 2010 | RIM BlackBerry Storm 9530 Smartphone
Blackberry error code
all you need to do is sync your blackberry with your blackberry desktop manager and run the application loader. you will lose all data on the phone because you are re-installing the software
Mar 01, 2010 | RIM BlackBerry Pearl 8120 Cellular Phone
Brightness and contrast increases suddenly
Check following:
1- VGA chord; is it loose or faulty?
2- Power Supply section not regulating perfectly.
3- Supply line from SMPS/Regulator power supply to EHT.
4- Brightness lines and controls (Resitance may be dry soldered or burnt)
5-Pin connection on rounded board of CRT neck may be loosed, Check it if loose than fit properly.
6- Adjust the precet for accelearting and focusing anode externaly fixed with EHT if inbuilt in EHT than only solution is to replace the EHT only.
Feb 15, 2010 | LG Computers & Internet
Mms not working
Hi, Please check if the mms services are activated with service provider on your blackberry device. If not activated then please contact your service provider to activate. still not working then the service book for mms may be having some problem. Contact your service provider to send the service book for mms.
Oct 26, 2009 | RIM BlackBerry? Tour 9630 Smartphone
Suddenly when my blackberry pearl connects i can not hear anything why?
In this case kindly check the volume of your Handheld, If it is low please increase the volume.Still if it is not working you need to walk into the service center to check the hardware of your speaker.
Oct 18, 2009 | RIM BlackBerry Pearl 8100
BB 8310- Speaker not working but headset and handset mode working
Install Blackberry desktop Manager ...Take Backup..
Reinstall the Software ....
if not happening contact service center as there might be any hardware problem.
Aug 13, 2009 | RIM BlackBerry Curve 8310 Smartphone
Sudden increase in water pressure
Replaced the pressure switch and water pressure returned to normal.
Jun 16, 2009 | Plumbing
White screen
youtube is the best
Sep 26, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry Curve 8310 Smartphone Logo
359 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
