Question about Avery BusinessCardsforLaserandInkJetPrinters,CleanEdgeBusinessCards-ForUseWithInkJetPrintersWhite,CardPerS... (AVE8870) Network Adapter
Printing ONE rotary card on a sheet wastes the rest.
If I only need one card and I'm printing on a page of three cards, I have two more cards that are wasted.I s there a special product or type of card with a backing? I wouldn't think it possible to punch out one card and rerun the page? It's not cost effective to replace my typewriter for the little typing I do, but I can't think of any other method.
    Problem Solver:
  • 8 Answers
Usually Avery gives you the option of where to start your printing. I suggest you print on the last card, then you can rerun the sheet later.
Posted on Jun 03, 2009
There was bits of paper, from a stuck edge from a sheet of business cards that I think are perhaps still in the printer. When I print a colour sheet the alignment is off, printing black and white seems OK.
What do you mean by alignment?
If you mean that the colours are misaligned, run a full calibration. Repeat it three times and then try your printing.
If bits of the business cards were left in the printer - it should affect the colour printing as well as B + W. You would also be getting paper jams.
Oct 25, 2010 | HP Color LaserJet 2600n Printer
My Business Cards
You need to set the print size to match the size of the card.
you either need to resize the document or change your print preferences to match the size of the card.
May 16, 2008 | Avanquest MyBusinessCards (824592)
How do I print just one mailing label without running through an entire sheet time I print using an Epson LQ-590 and printing from the mail merge option in MS Word (MS XP)? In other words, when I print...
I assume you are using a sheet of labels, such as the typical 3 x 10 sheet. Word sets up the mail-merge document for printing the whole sheet, so if you print just one or two labels, you will `waste' the rest.
One way of using that sheet over is to create a mail merge that contains blank `dummy' addresses. It is rather involved and at best time consuming, and considered not worthwhile to save a partial sheet.
I service printers, and personally do not recommend that any label sheet be re-used. The printer curls the paper, in some cases fuses it, and causes the corners of the labels to be exposed, and possibly get caught in the printer (I have removed a lot of labels from inside printers)
Oct 18, 2010 | Office Equipment & Supplies
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
Canon mx850, paper jams when reloading for two sided copies. once the 1st side is printed the paper is released, recaptured and starts to feed back into the prt. 1/3 into the feed it jams, paper is...
Mel, this is what I found in the online manual:
Set the Ink Drying Wait Time longer.
Doing so gives the time enough to dry the printed surface so that paper curling and ink blots are prevented.
(1) Make sure that the machine is turned on.
(2) Open the printer properties dialog box.
See Opening the Printer Properties Dialog Box Directly from the Control Panel.
(3) Click the Maintenance tab and then Custom Settings.
(4) Drag the Ink Drying Wait Time slide bar to set the wait time, and then click Send.
(5) Confirm the message and click OK.
Make sure that the actual size of the paper is suitable for automatic duplex printing.
The sizes of media suitable for automatic duplex printing are A4, Letter, A5, B5, and 5" x 7".
Load paper of suitable size and then press the OK button.
Make sure that the Page Size or Paper size setting matches the actual size of the paper with a size suitable for automatic duplex printing.
First, check the Page Size or Paper size setting in the application software you are printing from.
Then, check the Page Size setting on the Page Setup sheet in the printer properties dialog box (Windows) or the Paper size setting on the Page Setup dialog box (Macintosh).
Note
Depending on the version of the application program, the automatic duplex printing may not be supported.
Make sure that the type of loaded paper is suitable for automatic duplex printing on the Main sheet (Windows) or the Quality & Media sheet on the Print dialog box (Macintosh).
Note
To switch to manual duplex printing, follow the procedure below.
Open the printer properties dialog box, clear the Automatic check box on the Page Setup sheet, and reprint.
When performing manual duplex printing, note the following.
If you are printing three or more pages of a document with manual duplex printing, one side of all sheets of paper will be printed first. Turn over the paper and reload the paper in the machine, and then the reverse side of all sheets of paper will be printed. Be careful not to change the order of paper in the stack.
The procedure for reversing the paper varies depending on the staple side and printing orientation. Follow the on-screen instructions.
MX850 series On-screen Manual for Windows:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16279
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Canon PIXMA MX850 multifunction InkJet...
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Problem printing business cards
    I had this problem today and think I've figured it out. Take a sheet of plain paper and two little pieces ot clear 'scotch' tape. Tape the blank sheet behind the business cards at the top/feeder edge and try again. You may need to tweak it a bit more but it stops it from printing so far up.
    Jul 19, 2008 | HP Deskjet 3845 InkJet Printer
    Printer prints first page with strange nonsensical characters
    I would move the printer to another computer. See if the problem follows. I have seen the issue a few times with issues in normal.dot but also in other office applications.
    Problem I'm fighting with on my 1720 is its printing extra pages between pages. basically print a 5 page document and get an 8/9 page final with the extra blank pages. Think its a user error but could be machine related. going to try it on another PC and see what happens.
    May 28, 2008 | Dell 1720dn Laser Printer
    in your program adjust the pic your printing to fit in yours sumtimes u have to adjust your print in preview box your card u made down or up whole thing so it fits in nice for u sumtimes they just dont line up right i had same issue just move your project up with it ok to make it print in box cards u need ok
    Mar 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
    Only prints business cards correctly on plain paper, but not on the card stock.
    I am the guy with the hp d'jet D2445. I ran out of card stock in failed attempts. Not wanting to give up I bought more (Avery, no serrations) and it worked fine. Don't ask why.
    Oct 21, 2007 | HP PSC 1410v All-in-One Printer
    Avery BusinessCardsforLaserandInkJetPrinters,CleanEdgeBusinessCards-ForUseWithInkJetPrintersWhite,CardPerS... (AVE8870) Network Adapter Logo
    98 people viewed this question
    Top Avery Computers & Internet Experts
    Donna Sander
    Are you an Avery Computer and Internet Expert? Answer questions, earn points and help others
