Question about Olympus FE-330 Digital Camera
Canon P-Shot A630: broken lens cover
The cover for the lens on this camera is 4 small segments that slide back from the center of the lens when the camera is turned on. Our toddler grabbed the closed camera, with fingers on the lens cover, and 1 of the 2 larger segments broke off of the cover. One of the 2 very small segments, located in the bottom corner, that would normally slide off the lens with this missing segment, remains on the lens when the camera is on. I think it's possible that this piece broke off as well, and it's only jammed into that corner, since it's positioned differently than its undamaged counterpart.
Bad idea to try removing that small piece?
We had already begun plans to upgrade to a digital slr when this happened, so I'm thinking we just deal with a lens that isn't covered completely until we get the new one in our hands.
Appreciate your thoughts, love the blog.
Thank you!
  • mcdiscard Jun 04, 2009
    Possible for you to explain why entire lens needs replacing?
    Camera works same as always, only there is a small dark smudge in the lower corner of any photos because of the piece of the cover that is not fully retracted.
    Not sure how, but this question was originally submitted under the wrong camera type -- you saw this is actually a PowerShot, right?
    Thanks.
    Problem Solver:
  • 5 Answers
Sory ,but yuo heve replace the lens
Posted on Jun 03, 2009
2 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: broken lens cover **RESUBMITTED to Corrected Camera Type**
It's not really a problem if the lens cover isnt there. The following actually shows how to repair a broken lens cover. But have a feeling yours may be damaged beyond repair, so the next option is removal of the shutters. Be careful that you don't get any of the rubbing alcohol that's spoken of in the following procedures on the lens itself.
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Jun 04, 2009
Ecently a small dull black dot has started appearing on my canon power shot A630's lcd screen but when I review the pics taken prior to when I noticed this problem, no dot appears.
1) this is indicative the lcd camera has been faulty.
2) you must replace it.
3) contact your company supplier, and get the parts, you can do it yourself, only need small screwdrivers and common sense.
God bless you
Sep 17, 2012 | Canon PowerShot A630 Digital Camera
I don't know how to open the battery door for the
Slide the latch in the center of the battery cover toward the front of the lens, then flip open the cover. It's hinged toward the center of the body, so it flips open in that direction.
There's an illustration in the "Preparations" section of the Basic manual (page 5 in my copy). If you need manuals, you can download them from
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a630#BrochuresAndManuals
Aug 11, 2011 | Canon PowerShot A630 Digital Camera
The lens cover doesn't open fully Canon A630
Sure it is, and repair isn't that hard. See this link for tips on repair of sticky automatic lens covers. Recommend reading the reader's comments section of the link for additional tips. Especially pay attention to the vacuum cleaner tip.
Feb 08, 2010 | Canon PowerShot A630 Digital Camera
My A630 got wet and has a water stain behind the lens. Can I remove the lens to clean the stain?
You can but, you must be VERY careful.  It isn't like a film camera.  Everything must be lined up perfectly when you put it back together.  There is also a very small pickup behind the lens that will need to be cleaned.  It is about 1/8" X 1/4".
Jan 19, 2010 | Canon PowerShot A630 Digital Camera
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
Canon lens cover won't open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 09, 2009 | Canon PowerShot A630 Digital Camera
Broken lens cover **RESUBMITTED to Corrected Camera Type**
Jun 03, 2009 | Canon PowerShot A630 Digital Camera
Canon powershot a630 lens is stuck
My lens was stuck inside the camera and would not come out when I turned the camera on. I could hear a sound but nothing was happening with the lens. I used a dental pick (small sharp pointed object) to pull at the lens and it came out and seems to be working fine. Just tried it a couple of hours ago and It seems to be OK.
Dec 09, 2008 | Canon PowerShot A630 Digital Camera
Olympus FE-330 Digital Camera Logo
341 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
