No power to TV
My new TV - 3 weeks out of warranty - has just stopped working, no power to it at all.  Have tried plugging it in to various sockets, nothing.  Tried chaning the fuse, still nothing.  Any other ideas before I call in the repair man!!!
  • 2 more comments
  • Samas Oct 24, 2007
    Make: Samsung
    Model: WS32Z409T
    Model Code: WS32Z409TQXXEU
    Type No: 0Z32Z40
    Fuses were not bad as both fuses worked in other appliances.
    Switch on TV at plug - no power to TV - no power light came on.  Had been working fine the evening before.  Have tried different wall sockets, which are working fine.  Tried 2 working fuses. Still no power at all.
    Any advice greatly appreciated!!!
  • micha465 Nov 07, 2008
    samsung ws32z409t .lopt j6920a s/c,do you have a cause for this
  • andy41gil Feb 24, 2009
    dead tv all fuses ok on board to
  • alanie12 Mar 22, 2009
    in a samsung ws2z306,it seems a design fault in samsung ,don't buy this model.
    it is the LOPTX fault and J6920 transistor(expensive) and change CAP680NF ,i do not know how to do this ?any help
  • 1,694 Answers
Make,model,month & yr built (off sticker on back of set) ??
Also,clarify symptom??
Changed fuse-was it bad??
Posted on Oct 24, 2007
  • Vista Electronics Oct 24, 2007
    Check horiz output transistor = replace,if shorted along with
    chemical fuse (soldered in pico or micro type)
    If not,then check power supply/voltages = may need service literature....
No video,no audio, and no indicator..
Is this a new television? If so, then plug something else into the same socket.. If the socket is working then you should examine the TV to see if there are any signs of the electricity to the TV (exterior.. do not take it apart). If there is no electricity in the TV then it may have a bad power supply or a bad cord. Best thing would be to take it back.. Most TV's come with a warranty.. If the warranty has expired you can usually talk with the store and even with the manufacturer appealing to them that the TV should have lasted longer... I usually ask them if they can make a consideration in this case.. Sometimes they will. I once got a brand new Sony Digital camera that was out of warranty because I reasoned with them that a $1000 camera should last longer that one year and one week (that is when it went out).. Negotiating is powerful.. At least you are taking a shot... Who know? You may win.
If the TV is used... Same as above with the tests.. I have repaired my own TV's before BUT I DO NOT RECOMMEND THIS BECAUSE IT IS VERY DANGEROUS. There is a high chance of deadly shock within the TV.. Don't take the TV apart yourself! You can find a used TV on Craigslist.. I have even seen people giving working TV's away because they just bought a giant screen or something....
I hope this will help you,
Oct 28, 2013 | Televison & Video
Mitsubishi vs 60707
pleaser eset you TV as below.
Turn off and remove the power cord from the main socket.
leave it for about 30 min
turn back on again.
please make sure your sleep mode is off.
May 19, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Insignia lcd tv shuts off after 2-3 seconds
The TV seems to have a failing Power Supply. This could potentially be repaired but would be an out of warranty expense.
Dec 14, 2017 | Insignia IS-DVD1001 DVD Recorder/VCR
I unplugged tv to move it across the room now it wont turn back on??
  1. Connect tv directly to socket without any powerboards and make sure the power cord is properly inserted (if it works than any powerboard you have been using is probably faulty)
  2. Try a different power cord
  3. See if socket is dead using another appliance. If another appliance works then the Tv is probably damaged (refer to warranty if applicable)
  4. if other appliances don't work in that socket check your fuse box.
  5. If fuse box is fine then try a different socket (if it works you may need to get an experienced person to fix the socket your trying to plug the tv into)
Dec 20, 2010 | Televison & Video
My Canon PIXMA 640 will not switch on. I've replaced the plug fuse and plugged it into a new socket. Still dead. It's only 3 weeks old. What is likely to be wrong? How can I fix it?
If it is only 3 weeks old it will still be under warranty. Don't try to fix it as you will void the warranty.
Return for repair/replacement.
Sep 03, 2010 | Office Equipment & Supplies
Tv black out on me and it stop working. No red power light.
My friend bought a Poloroid tv, similiar to yours. The power supply went bad 2 weeks after warranty expired; he had to pay to have a whole new power supply installed - roughly $250. Two weeks later my Toshiba (same age) won't turn on - no lights or anything. Same thing - power supply. Sounds like yours is in the same category. Hopefully you bought the extended warranty.
Aug 03, 2010 | Protron PLTV-32 Television
Panasonic TH-42PX75U won't turn on
Your powerboard is damaged, and need to be replaced.
Sometimes it appear the TV is working again with no problem but it is only a matter of time for the board to get completely damaged.
May 30, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Dell E197FP LCD Monitor won't turn on completely dead
could be dead, but check to ensure that you are using the monitor ONLY, not TV tuner device. as a standalone, not hooked to cpu if there is no power light when plugged in assume your buying a new monitor.
Jun 21, 2008 | Dell E197FP LCD Monitor
I actually bought the 5 year warranty when we purchased this new and it was still under warranty. Gateway is sending us a brand new TV. No need for me to try to fix this, but thanks to all involved.
May 29, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Vizio 42 inch tv Power Not working
It's very easy to swap the entire power supply board. If it's out of warranty, what do you have to loose? You can purchase a new power supply board from Vance Baldwin. They are the ONLY parts supplier for Vizio. Once you receive the new board, it's just plug and play. Crack the case (a series of small screws around the back perimeter) and remove the old power board and replace it with the new one. It's that easy!
Jul 27, 2007 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
1,088 people viewed this question
Top Televison & Video Experts
