Question about Copystar CS-1530 Copier
Copystar 1530 copier Power Source PCB defective
My Copystar 1530 copier Power Source PCB is not working. No lights, no sound when turned ''ON''. The Power Supply PCB is not outputing the specified voltages. Where can I find a replacement PCB? The board bears a P/N 2AV2805. Need Names, Phone Numbers and approx price if possible. Can it be repaired? Is there a schmetic available?
  • hedgeslaw Jun 04, 2009
    Checked fuses (2) on power supply board-all ok. The voltages on the output side were a little low, so took it to local repair tech who replaced 8 or 10 capacitors that had dried out. All output voltages came up to spec on the bench and hooked up with load, but copier still does not power-up. Power switch and safety switches were ok too. Are there more fuses? I looked under every panel without luck. Suggestions?
    President:
  • Copystar Master
  • 990 Answers
Hello sir; You have to make sure this board got problem (reminder; did you check the fuse) after you bought the board that's non refundable, if you still need that call me at 9735336778 Everett Lin.
Posted on Jun 03, 2009
Copystar cs-1815 error code 3200, how can it be fixed
If it is a c-3200 code it means that you have a exposure lamp problem.Defective scanner,defective scanner PCB,lamp or inverter board,incorrect shading,poor contact of the connector terminals on lamp assembly. Look for a bad connection And look at lamp. Look for blue rings or burnt ends. Now don't look at that light while its on.
Feb 02, 2015 | Copystar Office Equipment & Supplies
My Kyocera printer won't turn on and is giving me an error CFB31. How can I fix this
This is a communication problem between the Panel PCB (don't know which one) and the controller PCB (I suppose this the main PCB - Difficult to say because i have the info in German and have to translate). Symptoms are as you said a blue, or black screen. Possible source of fault is Panel PCB, controller PCB, or connection cable
Jan 05, 2015 | Kyocera CopyStar CS-3060 Black and White...
I have a Kyocera Mita KM 1530. User maintenance, the lights are now lit. Now I know I need to replace the drum, but someone can tell me later if you need to reset some or mute only the drum and is already...
press in sequence 10871087...
Go to U251 using cursor keys.
Check and clear PM count(copies since from last PM and PM reset).Press start to display six digit PM cycle. Select "Clear" w/ cursor up/down to clear count back to ..
Go back to U001 and press Start key to exit.
Sep 16, 2013 | Kyocera Mita Km 1530 2030 Copystar Cs 1530...
Code c4000
C4000 Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on.
Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable.
Defective polygon
motor.
Replace the LSU.
Defective engine
PCB.
Replace the engine PCB and check for cor
Jul 10, 2013 | Copystar CS-2050 All-In-One Printer
Error code J50 on a Copystar CS-1530
check for jam in the exit unit of the copier.if there is no paper in there then the exit unit sensor is either dirty or not getting back to original position.check it if ur a rep or call one
Jun 05, 2011 | Copystar Office Equipment & Supplies
Kyocera mita 5035 code 6400 c
Zero-crossing signal problem
• The main PCB does not detect the zero-crossing signal (Z CROSS SIG) for the time specified below.
Causes
Poor contact in the connector terminals. - Check the connection of connectors YC1-3 on the main PCB and YC2-6 on the power source PCB, and the continuity across the connector terminals. Repair or replace if necessary.
Defective power source PCB. - Check if the zero-crossing signal is output from YC2-6 on the power source PCB. If not, replace the power source PCB.
Defective main PCB. - Replace the main PCB if C6400 is detected while YC2-6 on the power source PCB outputs the zero-crossing signal.
Dec 18, 2010 | Kyocera Mita KM-5035 Printer
Ap keeps popping up can't remember what that means
Hello dear; Don't worry about "AP" means adding toner, machine is working on that.
Mar 09, 2009 | Copystar CS-1530 Copier
I have a cs-1530 and when using the auto-feed the copies made come out with a black line down the middle.
Dear Sir; Open the cover on the left hand side have a piece narrow strip glass (or white reference on the cover) use rubbing alcohol to clean it.
Jan 10, 2009 | Copystar CS-1530 Copier
Km1505 digital copier machine
I would suggest that you confirm proper fixing heater supply turn on from Power source PCB to fixing unit if possible. Or replace it with a known good one (part# 2A1280551). If you are getting a low AC voltage reading at the heaters when they should be heating you may have a defective Triac or relay on the power PCB. If that is all OK you are probably looking at the main PCB as a source of the problem as it sends turn on signals to the power PCB.
Dec 29, 2007 | Office Equipment & Supplies
Copystar CS-1530 Copier Logo
126 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
