Question about Poulan Pro Chain Saw 46cc 20"
I have a poulan 305 pro chain saw were do the 2 fuel lines go?
I opened my chain saw and saw that the 2 fuel lines were broken so i went and baught them but now i dont know were they go because they were broken off. there is one valve at the top of the carburator and one at the bottom. but im not sure were the one with the little filter inside the gas tank goes and were does the other one goes. Do u have a diagram for this?
thank you so much!
Sincerely
Tony
    President:
  • 2,220 Answers
Find your model nuber here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The drawing containing your fuel system is as good as it gets. If you need more help contact PoulanPro.com. HTH
Lou
Posted on Sep 18, 2009
Need fuel lines diagram for poulan pro ppb1838 chain saw
How to ... Poulan Chainsaw - replace fuel lines - YouTube
? 5:05
www.youtube.com/watch?v=jZqCNiYgF3g
Mar 27, 2012 - Uploaded by minthillbilly ... and demonstrates how to diagnosis and repair a Poulan 2700Chainsaw. ... I have a brand new Poulan Pro, the hose went bad
Jul 31, 2015 | Poulan Garden
Install fuel line for Poulan 2050 chain saw
What i normally do is slice the hose up the middle to approx 2" take away on half, the hose is now only half the diameter at one end, push this into the top of the tank, take a pair of long nose pliers through the open fuel filler hole, grab the end of the hose and pull it through, trim the end and re fit the fuel filter.
Oct 26, 2011 | Poulan Pro Chain Saw 46cc 20"
I NEED HELP WITH FUEL LINE ROUTING FOR POULAN 445 PRO.
I HAVE A POULAN PRO 445 POLE SAW AND NEED AN FUEL FILTER AND HOSES . IS THERE ANY WAY I CAN SEE PARTS # FOR THESE ITEMS AND ALSO A PIC OF PUTTING IT TOGETHER ? Thanks , Omar
Jul 13, 2011 | McCulloch 10" Electric Pole / Chain Saw
Gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Jun 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Carb. connector hose to air filter keeps melting.
There should be only two small diameter hoses (lines) that connect to the carburetor--one comes from the fuel filter in the tank and the other connects to the primer bulb. If either of these is melting/breaking from heat, someone has replaced them with inferior rubber/plastic tubing or you have some serious engine heat problems! Buy the correct lines from a Poulan saw dealer and replace the junk. If you had that much heat, it would have seized the piston in the engine. After the lines have been replaced, check the fuel filter, air filter, and muffler for plugging. Start the engine and after warm up, open the throttle fully. It should 4-stroke but immediately 2-stroke when cutting. If it 2-strokes at all times, then the 'H' jet needle may need to be adjusted. Don't ignore this as it causes overheating, low power, and possible engine damage. Hope this helps!
Jun 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
May 07, 2010 | Poulan ES350 16" Chain Saw
ON a Poulan 220 Pro all of the fuel lines are
Let us start with the bleeder. The 2 hoses that connect to the bleeder are different sizes (Important). If the nipples are the same size connect a hose temporarily to one of them and place the free end in a small container of mix (please be careful with open gasoline and as soon as it is no longer needed put it out of harms way.). Squeeze the bulb if it blows bubbles that is the return side, it gets the large hose and attaches to a fitting on the tank. If it appears nothing happens but when released fuel is drawn into the bleeder it requires a short section of small hose and attaches to one of the carburetor fittings.
A second small hose goes through the tank and connects to the carburetor just like the video including the filter. It feeds the carburetor like it has since before bleeders were installed. I am not certain which carburetor fitting connects to the tank or the primer, please leave them long enough to swap until the saw is running. Logic says the upper most fitting (air bleed) goes to the primer but that is not always true. The Poulan drawing is deceptive it appears the filtered line feeds the bleeder it does not!!!
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but are on different illustrations. They are also beneficial with disassembly/reassembly.
A link to a Poulan "PP220 Gas Saw Type 5 follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP220-Gas-Chain-Saw-Type-5/75.PP220-Gas-Chain-Saw-Type-5.1.59.1.html
If your saw is not a Type 5 you can find the correct IPL here:
Poulan.com
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 06, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fuel line routing
A typical fuel system and a couple of suggestions follow:
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
If not your saw, yours can be found here:
Poulan.com
I am reasonably sure the upper most carburetor connection (it bleeds any air in the carburetor, air rises) goes to the primer. Leave the hoses long enough to swap them and try it. They can be shortened once you verify the correct routing. Good Luck. HTH
Lou
Feb 24, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
570 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
