Question about Ovens
All 220v appliances stopped working at the same
All 220v appliances except central air stopped working at the same time
  • 20 Answers
Your central air may have its own circuit box. If you have already checked your main breaker box and the switches are not tripped (flick them off and on anyway) then you may have had an overload that caused your main wire from the power service that enters the house to get burnt out.
Posted on Jun 03, 2009
Ovens work fine . .ONCE ! Then buttons do nothing until you turn off the wall breaker for an hour. Then the oven works ONE time again.
Tom Sh, you own every kind of appliance, or you are attempting to be a repairman with free advice from Fixya?
Replace the touchpad. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Ovens Ovens
No heat in either oven
DCS by Fisher & Paykel
5900 Skylab Road
Huntington Beach, CA 92647 spacer.gif contact_general.gif spacer.gif 888.936.7872
949.790.8900 spacer.gif contact_tech_support.gif spacer.gif 888.936.7872 spacer.gif contact_service_parts.gif spacer.gif 888.936.7872 spacer.gif spacer.gif contact_tech_questions.gif techsupport@dcsappliances.com spacer.gif
Jan 13, 2008 | DCS (WOTD-227) Double Oven
Tip
Oven Repair ? Your Oven will not work at all
If your Oven, Kitchen Range, or Cook Top is not working at all then here are some things that you can check out to see why it is not working. As always be aware that electricity can kill you. Make sure that you use care and have the power turned off when working with the wiring of these appliances.
The first thing to check is to make sure that the circuit breaker or fuses are giving you the proper voltage. At the connection point of your appliance, you should have 110v to ground at both legs. (The red and black wires.) It is also very important that you check the voltage across the red and black wires. You must have 220v across them. It is possible for the 110v to feed back through the appliance and give you the 110v at each wire, but you still do not have 220v to the appliance if you do not have the 220v across the legs. Some circuit breakers will trip only one side and resetting them can take a bit of effort to get them to reset properly. Pull fuses and check them with an ohm meter to see if they are blown or not. If they are open they are no good and will need to be replaced. NEVER replace a fuse with a larger one or jumper the fuse in anyway!!! That is what burns down houses!!
Next, check the wires at the terminal block connection of your appliance. The terminal connections will often become loose after heating and cooling many times. When the connection becomes loose it will start to heat up and then the whole problem gets rapidly worse. If you have a burnt wire or a burnt terminal lug, cut off the wire if you can to get to good wire, or replace the terminal block on the appliance. If you do not make the extra effort to reattach the wires properly, you will soon have the problem all over again.
If you have an outlet that your appliance plugs into, check the outlet and the plug for signs of heat damage. If the plug or the outlet have burn marks on them you will need to replace them both.
These steps are the first in the troubleshooting process of many major appliances. Once you have verified that the appliance is getting the correct voltage, then you can continue to check out other things that may be causing your problem.
http://www.fixya.com/support/r4319770-maintenance_range_stove_or_oven
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r4501853-oven_cord_wiring_oven_3_wire_or_4_wire
on Apr 06, 2010 | Ovens
1c2c is on controls of jenn air wall oven. not working m#JMW8530DAS
We've had a Jenn-Air wall oven & microwave, Model #JMW9530DAS for 9 years. We never had any problems with it except for the irritating dust that collects between the oven glass. After returning from a 10 day vacation, we got a 1c2c error code when pressing "Bake." The oven worked fine before we left so we were baffled. We tried other settings like "Broil" "Convect" to no avail. It kept telling us to call for assistance. We tried shutting off the power to the unit for a few minutes but got the same 1c2c error again. So we called a local appliance repair shop (associated to the appliance store we purchased the unit from) and paid a fee to have him assess the problem. He really couldn't pinpoint the problem but suggested it "could be the membrane or the controller." And, to top that, he said Jenn-Air stopped making the membrane but they are going to start making them again and we could get one in 6-8 months at a cost of $500. So now we were looking at a $300 controller & possible $500 membrane....plus labor. We were so frustrated that we decided to tackle the problem ourselves before going out and buying a new oven. We shut the power off and tried pulling the oven out of the wall. Too heavy. After about 20 minutes of the power off, we turned it back on and decided to use the "SetUp" feature as if we were using the oven for the first time, following the directions in the instruction manual. We stepped through the process (clock, auto convect, language, C/F, etc...) then pressed the "Convect" button (instead of "Bake") and voila! It worked! After the Convection Bake Preheat worked successfully, we pressed "Bake" and it worked, too. We just saved ourselves over a thousand dollars as we were going to get rid of the piece of junk. So, before you give up, try turning the power off for a half hour & use the SetUp key and walk through the process.
Feb 13, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
Everything works except the heat. Light on oven temp adjustment not coming on. Circuit boards look good. No burnt or overheated wiring. Transformer looks good, not certain how to test heat coil.
Is it 220v??? If so make sure u have correct voltage. All the oven lights and circuit boards are ram off 120v. The element probably requires 220v to operate.
Also take multimeter and check continuity across element. Should make meter beep or display will read 0.00.
Dec 28, 2012 | Ovens
We just reinstalled a used unit that was working when it was removed. Everything electronic on the top works perfectly but neither element will heat up. Please help! My husband is horribly frustrated and I...
Hello, W/D here.
Quick check: Make sure that you are getting 120v on each of two legs, as you need both 120v legs to get 220v for your oven to operate. It's possible that if you are getting 120v the control panel will operate, but the elements will not.
Best regards, --W/D--
Feb 08, 2011 | Ovens
Oven does not work,no display.
the display board itself would be the culprit,the part might be under warranty,if under 5 years consult manual or manufacturer for coverage....the part is probably expensive
Mar 06, 2010 | Whirlpool RBD305PD Electric Double Oven
The motor in our Jenn-Air central downdraft has stopped working. It's an electric cooktop. We think it's time to replace the unit; want to keep the central downdraft format, but this time want to have...
Not a problem . take a look at Jenn-air 's dual fuel . gas top elect oven and also down draft unit . can be vented several way's .. mm hope this helps . feed back pls . 84020
Dec 21, 2009 | Ovens
Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Jun 24, 2009 | Whirlpool RBS305PD Electric Single Oven
Neff B1721 oven
good day,
hope this link below will solve your problem.
kitchen appliances
Oct 20, 2007 | Neff B1721 Compact single Circotherm oven
Ovens Logo
427 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
