Question about Maytag PAV2300 Top Load Washer
Would like to see if I can purchase a pulley instead of the entire motor (MTR PN# 21001950)
Got the problem fixed but if you would like to know how i did it i will have to charge you.
Thanks ..
Posted on Jun 04, 2009
What the part no for main motor assy. The whole assy that needs to be replaced due to unusual grinding noise during paper run.
You cannot typically buy the entire assembly as one piece. You need to purchase the main motor and then all the related gears. There are companies out there that sell a kit with all the gears, look for one for the 5200 laserjet as they are the same.
Aug 31, 2016 | HP LaserJet M5025 MFP Printer
Fan spinning backwards
If its the original mtr. or was working fine before then mtr is bad replace mtr with new capacitor
May 17, 2013 | Intertherm P3RA-048K Air Conditioner
Motor works window does not go up drivers side 1997 grand marquis
u most likely have a bad gear pak in ur window motor,which can b serviced seperatly, or u have a window regulator that consists of plastic pulleys an steel cables monted on stamped steel frames,which are weak designs an almost always fails causing condition u decribed. if u remove dr panel u can see a bad regulator by noticing cables jus layn around not hooked to anything,or cables not routed thru the small plastic pulleys.if all ur cables are intact the gear pak which consists or plastic parts for safety reasons,has gone bad an can b serviced without buyng a new mtr, jus purchase the gear pak install an ull b bak in business. good luck
Mar 24, 2011 | 1997 Mercury Grand Marquis
I need a Part. My manual states my model # is 107624-01 or 107624-02. Parts needed are 107710-01 and 108640-01. I can't locate
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
Guide Bar Nuts (pn 107710-01) are available, $2.10
The entire sprocket cover (pn 108640-01) is not.
There is a "Sprocket Cover Adjustment Screw Repair Kit" available (pn 108640-MD), $5.95.
There is a "Sprocket Cover Bushing" (pn 107711-01; different model; may require modification) available; $2.10.
The bushings can probably be fabricated with the correct ID metal tubing. I really tried to help.
Are you aware RemingtonPower is no longer in production? Often eBay is the only source of replacement parts. If the replacement parts I located remedy your current problem nothing will remedy a burned out motor. Only you can determine if the money would be better spent toward the purchase of a replacement saw. I suggest a name brand that you expect to be in business for the next 10 years when it will need replacement parts.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 13, 2010 | Remington Garden
My treadmill is has had one problem after another and now the motor is out, what do i need to do to get it replaced? It has a 15 year motor warranty. It is actually a Proform Perspective 1.0 and that was...
How long have you had the item, manufactur will go by sales reciept/date of purchase-in most cases if mtr is under the man's warranties,they will replace mtr if defective,but labor to install will apply-read the owners manual of item- but what made mtr go bad-Friction between walking board/belt-they will want opion from repair place
Dec 08, 2009 | Proform XP 590S TREADMILL Drive Motor
Where is the speed sensor located?
owners manual will show this section, its under the mtr hood next to the frt roller pulley/mtr dr belt.
Nov 02, 2009 | Proform XP 542S TREADMILL Drive Motor
Doesnot spin or agitate.
if you have the front panel off and you can see the motor is spinning the belt is turning then your transmission has failed.waring keep hands clear of all moving parts! transmission pn wh38x10002 for around $185 if mtr is not moving pn wh49x10040 for about $240 depending on what you need and how old your washer is it might be time for a new one
Dec 13, 2008 | Washing Machines
Washer wont turn
possible motor or board fault need to detemine if the windings on motor are open if motor winding check at pin 1 to2 1to 3 2 to 3 each should read at about 3 ohms if mtr checks good you'll need control board pn 34001497 or 3400469 depending on series $220 mtr pn 34001269 $240
Dec 12, 2008 | Maytag Neptune MAH9700 Front Load Washer
Maytag PAV2300 Top Load Washer Logo
66 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
