Question about Westinghouse LTV-27w7 7 in. LCD HDTV
Westinghouse ltv32w1 has power light but no picture, has sound
    Problem Solver:
  • 7 Answers
Believe it or not...I repaired my Westinghouse LTV-32w6 HD TV. it had no picture and just sound. I took the back part off, I took the stand off, and then I took the metal plates surrounding the main board and back light inverter off. I inspected the backlight inverter, saw nothing bad, inspected the main board, saw nothing bad, inspected the power supply, and saw nothing bad. What I did notice was the flimsy aluminum foil tape that I guess is supposed to ground the metal chassis around the TV. I did not see any other means of grounding except this. In my opinion, this was poor grounding. I went ahead and took the main board off; at this point there are a lot of connectors you have to disconnect. The good thing about these connectors is that they are all unique so you really can’t connect them back the wrong way. So, I found another smaller metal plate on the back of the LCD. I took off the plate and I found that there was a board with the numbers “V320B1-C” on it. This board had four connectors at the top and 1 at the bottom. (yours might be different) I noticed that there was a burnt spot on the lower right side of the board. By the way, this board is called the LCD controller board. I thought to myself, if I replace this board, it can be fixed. I went on EBAY and found used boards for under $50. I even found out that these boards are also used buy 32” Poloroid LCD TV’s. Anyways I ordered the board, installed it, and BAM! The board exploded! It blew up at the same place the other board had the bunrt spot. Damn I lost about $45. OK, I was not about to quit yet. I should have done more inspections. I inspected the 4 connectors at the top of the board. It has 4 short flat cable strips. I noticed that two of them had very small burnt spots on them. So I took the LCD itself apart (many more screws to take off) and inspected the thin side boards and didn’t find anything bad. So I put the LCD back together and went ahead and ordered the same board on EBAY. This time, before you order the “V320B1-C” board, MAKE SURE YOU ASK THE SELLER IF THE 4 UPPER FLAT CABLE STRIPS COME WITH IT, IF NOT ASK HIM TO INCLUDED IT. It might cost a bit more but it would be worth it. If the seller doesn’t have the strips, then don’t get the board; keep looking. ALSO, COMPARE THE EBAY PICTURE OF THE BOARD WITH YOUR BOARD AND MAKE SURE THEY LOOK IDENTICAL. Some boards will have the same model but will look different. After you get the board and the flat cable strips, do a quick inspection on the board and cables to see if you notice any burnt spots. Install the cable strips and board, then put the metal plate on top of it. Connect all the wires back together to the main board, speakers etc. Put everything back together, EXCEPT the back part. Last thing, you will need wire strippers, and a piece of wire (about 2 foot, 18 awg stranded and insulated, like thin speaker wire). Remember the aluminum foil tape that supposedly acts like a ground, you will make a better ground. Look at the bottom left edge, the screw that holds down the metal chassis (any screw that touches metal), loosen the screw, get the piece of wire and strip the end to expose the wire. Wrap the wire around the screw and tighten the screw. Now run the cable up and around the edge of the LCD, skip two screws, loosen another screw that holds metal chassis, and cut the cable and strip to expose the wire and wrap the wire around the screw, but before you tighten, get a second piece of cable, strip it and wrap around the same screw, and tighten. Repeat this process until you reach the bottom center part of the LCD. Connect the power and cable to it and cross your fingers. I was so happy when I saw the WESTINGHOUSE logo come up on the screen
Posted on Nov 08, 2009
  • 822 Answers
Check inverter board and lamps connectors.
Posted on Jun 03, 2009
I have a Westinghouse lcd tv i have a thin green line on left of screen from top to bottom model #ltv32w1
T con board or the LCD panel is faulty.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 26, 2016 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse 19inch model 19h210s has picture no sound
Fix Your Westinghouse SK-19H210S Television - Instructables
www.instructables.com/.../Fix-Your-Westinghouse-SK-19H...
InstructablesI called Westinghouse and they said that I was out of luck because it was no ... on an the screen lights up an then off ?have sound but no picture after start up .
Westinghouse SK-19H210S has picture no sound - Fixya
www.fixya.com/.../t11272945-westinghouse_sk_19h210s_picture_no_s...
Jan 13, 2012 - Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board.
Oct 16, 2015 | Westinghouse Televison & Video
Tv turns on but no picture
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 15, 2014 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
LTV32w1 - powers up, indicator goes from blue to yellow. no sound and no picture. I've seen a lot of data on power supply issues and cold joints. is there any good pics or ideas on best way to get to the...
You need to remove the base and lay it down flat on a soft surface and remove all the screws on the back and pry open the back. Look for cold joints, the one in my pictures has cold joints on the one of the leg of retangular grey cap. I would usally inspect the board real well with magnifying glass and resolder just about all joints just to sure.
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find
Nov 12, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
THE tV GOES BLANK WITH NO SOUND 5-10 MINUTES AFTER TURN ON. The blue pilot light in front stays on and sometimes goes yellow . The Tv will sometimes work again if I turn it off and them back on.. Model...
Power supply board is going.Not giving the right voltage to the tv anymore.That why,power it is not consistance.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 26, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
I have a Westinghouse LTV-32w1 Televeision. My screen is cracked and I would like to replace it, as the TV works great. Where can I buy the screen?
You will pay more for the replacement panel then you will for repalcing the TV. The part number is LTV32W1-LCDP and is no longer avilable.
Sep 10, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Manual for LTV32W1 WESTINGHOUSE TV
You can download the required manual from:
http://www.westinghousedigital.com/pdf/15_User_Manual.pdf
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Aug 25, 2009 | Westinghouse Televison & Video
Don't have remote for westhouse ltv32w1, can't setup tv
Partstore.com has it for $19.95. It's under remotes, then TV remotes, then Westinghouse digital, then under LTV-32W1.
Feb 01, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
32inch westinghouse LCD TV flickers/slighly shaky picture-LTV32W1
try reseating the LVDS cable inside the set it is the multi wire connector from the main board to the LCD panel (top portion of the panel). if that doesn't look to see if the back lamps are remaining lit during this problem. if they go out the problem may be power supply or inverters (lamp power supply).. some panel makers make these available as a seperate part, some do not and the panel must be replaced. if the back lamps stay lit it is the main board. start with the LVDS cable first.
Apr 24, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
Mar 06, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse LTV-27w7 7 in. LCD HDTV Logo
724 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
