PC states, incorrect cartridge installed...color but it is the correct cartridge. I restarted it removed and cleaned the cartridge compartment but the printer viewer still shows the color cartridge is not installed.
SOURCE: Dell 962
Thank you ever so much I run a business and this really cripples me when this happens - and here's a solution Don't Buy Dell
SOURCE: dell 962 showing message "right cartridge incorrect"
Make sure the contacts on the cartridge and in the printer are clean. Also, try a new cartridge to see whether or not you have a defective one.
SOURCE: Dell All In One 962 Printer
Make sure that the contacts where you plug in the cartridge are clean. Also if you haven't yet done so, try another of the same cartridge.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
