Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Cant open the access door to get to the lamp housing
I believe that the access door to the lamp housing for kdf 42we655 42 is in the center of the console just below the flashing light that indicates that the lamp is burnt out.. is this correct? if so how do I get that panel open? I have tried pushing top/bottom/corners.. it seems to be stuck
If this is not where the access panel is>.. where is it??
Thank you
David Ryan
  • 80 Answers
2 possibilities.
1. On either side of the set just behind the lower left and right corners there are "thumbscrews". Loosen them and then pull the lower front off.
2. If there are no thumbscrews, just grab the front cover from the botton on either side and tug strongly, it will come off as it is held with small catches and springs.
Posted on Jun 03, 2009
  • Martin Forsythe Jun 03, 2009
    2 possibilities.
I bought a new Sony xl5100 lamp. Delicately and accurately replaced the old lamp with the new one. Installed the lamp and housing correctly. Closed the lamp access doors correctly. Turned on TV...red light...
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jan 11, 2014 | Sony (XL-2400) Projector Lamp for...
I have a sony kdf 655wf55 t.v, I'm not getting a picture. Turn the t.v on and the lamp comes on with audio but no video. The screen lights up and thats it. Put a brand new lamp in, but still the same....
It may not be something serious. In the lamp compartment there are a couple of plastic strip kind of things that hit the door switch when you close the door. Even though you have closed the door correctly, it is very easy for these strips to miss the switch. Please open up the lamp compartment and adjust the strips that the strips hit the switch when the door is closed. If it does not resolve the problem let me know and we will continue the diagnosis.
PS: Bad rating = No further help!
Sep 16, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
HI, My Sony KDF-E42A10 TV, power on then goes off blinks red 4 times and have checked the 2 fans that can be seen and are working until it powers off. Any ideas?
there are three fans . the one u cant see is above the lamp housing. u need to pull all the plastic
housing of to access to clean.
Apr 01, 2011 | Sony KDF-E42A10 42 in. LCD Television
How do I access the lamp on a Vega KF-60WE610?
This page shows Sony lamp location and bulb replacement.
Sony DIY Bulb Guide.
The XL2100 Lamp assembly is located behind the grill, under the front screen. Thumbscrews on left and right loosen and the panel pulls off.
Open Lamp access door by loosening the thumbscrew on the front. The lamp is behind the door and attached by two mounting screws. The mounting screws require an "Allen" or Hex key.
Never attempt to access the bulb or open the door when the bulb is hot. Allow 30 minutes to cool.
Look for specific LED indicator codes on the front of the TV. An explanation of the most likely fault is in your Sony user's manual. Links to free Sony user manuals are also on the link above. Lots of instructions regarding safety, mercury disposal, removing the lamp.
Do not buy a bulb and waste your money if any Sony TV Optical Block or Optical Engine Faults are or were visible before bulb failure.
easyab
Jan 27, 2011 | Sony XL-2100U Projector Lamp for...
Dont have my manual. where do i open the panel,
Hi, the lamp door is located in the front behind the pull off panel.
Thanks
Apr 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
HOW DO I GET MY LAMP OUT. I CAN'T FIND THE SPOT TO ACCESS THE LAMP ON MY SONY MODEL # KDF-E55A20
There are thumb screws at lower corners of TV, lose them and pull lower front panel, check near front control buttons you will see lamp door, open it and take out lamp. Put new lamp and put things in reverse order.
Thanks.
Jan 30, 2010 | Sony KDF-E55A20 55 in. LCD Television
6 blinking lights after changing replacement bulb
You have an open thermal fuse in the lamp housing. The fuse has an upgrade and is only accessible from the back of the TV>
Apr 15, 2009 | Televison & Video
Kdf-60xbr950 no pic or sound. standby light flashing
Sounds like the lamp is bad. Might be time to replace the TV.
Mar 31, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
No pic and shuts off
If the housing of the door comes open you will lose the sound and picture almost instantly. Have you replaced your lamp in this tv it sounds like the life on your lamp is coming to an end.
Oct 15, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
103 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
