Question about Kodak EasyShare C330 Digital Camera
2GB SD card is brand new but camera says it is full.
I have inserted a new 4GB sd card and the error message says: memory full on the camera symbol and on the green plat mode it states no files. Can you help please Hi, I have a similar problem to the one above, I have a Kodak Easy Share C330 camera which is about 5 years old, and have just brought a new Kodak 2gb memory card. When the card is inserted into the camera it says that the memory card is full, even thought it has not been used yet. What is causing this? I have tried to formatt the card on the camera, but it comes up with an error message. The memory card is recognised by new Panasonic camera however??!!!! Can any one help? Thanks.
    Problem Solver:
  • 8 Answers
Some of the older cameras will not take the bigger cards. You can use the bigger card with your computer to store your photos.
Posted on Jun 03, 2009
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
Inserted 4G memory card...says memory card is full...when I try to format the card, get filesys error e00100.....
The C330 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to go with cards 2GB and smaller.
Jan 11, 2011 | Kodak EasyShare C330 Digital Camera
This is a new purchase, never been used. I inserted the card, installed the batteries and then pressed the putton to turn it on but the display on the screen says "Memory Full! Please Insert an SD...
You didn't specify the make and model of your camera, but from what you do say I suspect it uses SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it's electronically incompatible. Try using an SD card 2GB or smaller.
Jan 03, 2011 | Cameras
I inserted a new 4gb sandisk memory card and get a "card error" message with a "00001" in top right corner of display. any advise? thanks.
The 5022 is specified to work with SD cards. Your 4GB card is actually an SDHC card. While it will fit into the slot, it is electronically incompatible and will not work in the 5022. You need to use SD cards, 2GB and smaller.
Oct 11, 2010 | Vivitar ViviCam 5022 Digital Camera
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
SD card
It seems that you are using an SDHC (Secure Digital High Capacity) card. It's incompatible with certain older models of cameras. I think the most you can put in your camera is 2GB. I've done some research and it doesn't say anything about your camera being SDHC compatible. Return the card, get a 2GB.
Jan 14, 2009 | Casio Exilim Pro EX-P600 Digital Camera
SD cards
Do the 4GB Cards say SDHC on them? They should. SDHC is simply "Secure Digital High Capacity". They're high capacity SD cards that hold more than regular cards. In this case, 4GB. The problem with these is that they need to be supported by the device. I've never put an SDHC card into a device that doesn't support them, but it looks like that's what your situation is. The highest memory capacity a non-SDHC compliant device is capable of 2GB. I recommend that you return the 4GB cards and buy 2GB cards instead.
Jun 16, 2008 | Samsung NV3 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
1,187 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
