Question about Canon MF8180C Color Laser MFC Printer
Supply rec paper tray - what does this mean when the tray is loaded?
Loaded paper into tray, but the printer will not print! Message : SUPPLY REC. PAPER TRAY
  • Tim Swiercinsky May 11, 2010
    What operation was trying to be accomplished, ie: printing, copying, recieving fax? How many paper trays are on this model ?
    Does it have a bypass (manual feed tray) ? Sometimes different functions (operations) are assigned to individual trays. Make sure all trays are stocked with paper.
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Posted on Jun 16, 2009
Supply rec. paper tray:ltr
1) unplug machine from power supply.
2) Under printer properties, select custom paper size and set it on A4 if you use A4.
3) Power on the machine and then try to print.
Hope that helped
Jun 29, 2010 | Canon imageCLASS D320 Digital Copier
Error message saying "supply rec. paper"
There is a small side tray on the right side of the machine,check if there are paper loaded in.
Jun 30, 2009 | Canon LaserClass 9000L Plain Paper Fax
"Supply Rec. Paper Tray : LTR"
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
I do not have a manual. What does supply REC. paper mean?
supply rec paper mean stay paper in copier cassette or that the paper print
it is mean insert paper in cassette
Dec 16, 2008 | Canon imageCLASS D320 Laser Printer
Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Oct 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
Canon Imageclass D320 supply rec. paper malfunction
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Jun 05, 2008 | Canon imageCLASS D320 Digital Copier
Supply rec. paper Tray:LTR
Sorry i said he reset it, he actually cleaned the feed rollers and run a bypass to allign the feed drive unit, I am getting him back in so i will keep you all posted on the outcome
Feb 21, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Msg:supply rec paper
Ya, I had that same problem too; I was printing something that was over printing margins, and then i had the message "supply rec. paper......" on the lcd screen. I ended up fixing the problem by clearing/canceling all the documents i was printing on my computer, and clearing/canceling all the documents saved inside the MEMORY OF THE PRINTER (note the green light with the "memory, in use" which means it's probably still trying to print the document that's too big, so it wont print anything else). (<--- not sure if that was your problem, but it was mine)
Anyways, to clear the memory inside the printer, i pressed the "status monitor" button located to the left of the "B&W start" button, and then i scrolled over to "print status, select job to cancel" and canceled all jobs, and then once i canceled all jobs, the alarm disappeared, and it was fixed XD
Feb 13, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
and PLEASE HELP
Make sure you check both paper sources, the side tray going empty will cause your alarm to go on
Apr 25, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Canon MF8180C Color Laser MFC Printer Logo
1,255 people viewed this question
old marine
old marine
