Question about Xerox Phaser 8500/DN Printer
Xerox Phaser 8560n 07,009,42:0 error.
After starting a Xerox Phaser 8560n printer it stops 16 percent and displays the code 07,009,42:0. It does this every time. I did see tiny pieces of ink on the drum. I used compressed air to clean it and checked for jams, there were none. What could be causing this error.
    Novelist:
  • 125 Answers
Hi oconde:
This is your problem.
7,009.42: The printhead is tilted back but not properly restrained in the park arms.
This will require a certified Xerox technician to repair.
Hope this helps
Posted on Jun 03, 2009
  • beachhousebl Jun 07, 2011
    Where does one find a technician who is prepared to have a look and not say it is a $3,000.00 repair job. Any ideas
Xerox Phaser 8560N PS error code 0805.42:187039
8,035.42: The Media Drive stalled while moving the cap/wipe Up.
Check for obstructions in the Wiper Assembly path.
Is the Wiper Assembly obstructed by the Printhead or wiring?
Apr 18, 2014 | Xerox Office Equipment & Supplies
My Xerox Phaser 8560N has paper jams very often. The codes from Troubleshooting->Service Tools->Jam History for the last 20 jams are: - N4W [9] - C3T [6] - P4V [2] - C3X [1] - M4F [1] -A2C ...
Most of these types of paper jam errors are caused by a cracked cam on the Drum Maintenance Camshaft, which throws the timing off for the whole print process. I would recommend a technician replace the camshaft because there are components that need carefully removed to avoid breaking, then they need to be properly aligned and timed when they are reinstalled. Not really a do-it-yourself repair.
Aug 29, 2013 | Xerox Phaser 8560N Laser Printer
Xerox printer 8560n won't print
First download and install printer's driver ..click here Select your operating system and language. Next try to print the configuration page ..--> Press the [Up] or [Down] arrow button on the Control Panelto select [Printer Setup] on the Display Screen, and then press the [OK]button. Press the [Up] or [Down] arrow button to select[Configuration Page], and then press the [OK] button to print. Press the [Up] or [Down] arrow button to select [Exit], andthen press the [OK] button to return to the Main Menu.
Apr 05, 2011 | Xerox Upgrade Phaser 8560N to Phaser...
Printing stopped and got error code 09,038.46:79929 on Xerox Phaser 8560. can you help please?
Can you try this.
Switch off and switch on the printer
Hold the back and help buttons
Go to service mode.
Scroll down to the function menu
Scoll to clear isc fault
Hit the back button to get back to the first menu then exit diagnostics,
Hope this helps.. Good Luck
Siju.D
Nov 05, 2009 | Xerox Phaser 8560N Laser Printer
Xerox error code 09,038.46:350??
Hi. The error code you are referencing is referring to Black Ink Stick Count Failure.
  1. Make sure you are using Phaser 8500 ink sticks
  2. Make sure the ink sticks slide properly
  3. Remove any broken or partial ink sticks from the ink-loading bin
If the fault code is still displayed you will need to contact support to schedule a service call.
Please check out the online support at www.xerox.com\support
Oct 24, 2009 | Xerox Phaser 8500/DN Printer
Our Paser 8560n won't print, sz Fault code
Here is the info from the service manual
Harry
8500/8550/8560 PEST description
37,017.44: Deskew Clutch Disconnect.
The Deskew Clutch is not
drawing the expected power.
Oct 09, 2009 | Xerox Phaser 8560N Laser Printer
My error code is 09,038,46:6774 xerox phaser 8560
Off the printer. Remove all the cables, wait 5 min and put cables back and restart it again.
or
remove the toner and put it back.
Apr 23, 2009 | Xerox Phaser 8560N Laser Printer
Xerox Phaser  8500/DN Printer Logo
980 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
