Are load range D Uniroyal Laredo LT225/75R16 load range D tires satisfactory, if hauling a full load of passengers or should D Uniroyal Laredo LT225/75R16 load range E be used.
The load range refers to what used to be ply ratings, it is now the grade for holding pressure at load, a "D" range is equal to 8 ply, and the load index for this tire is approx 2300lbs/tire, the "E" rating is equal to 10 ply, and the load index is approx 2700lbs/tire. If you are hauling 12 passengers at 200lbs/passenger plus driver total is 2600lbs. I would say the "E" rated tire is better for that application. If you need more info you can go to google and type in understanding tire markings or ratings, and there are several sites that will cover all tire markings in depth, I hope this helps, let me know
And i put lt225 75 r16 load d on a van that has lt225 75 r16 load e the fan is a ford e2500 cargo van
