Question about Hayward 1.5 Hp Northstar High Performance Pump
Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor
Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor.
    Scholar:
  • 151 Answers
The pump seal is bad on the unit. This requires disassemble of the pump unit. Remove power to the unit, dissasemble pump housing, remove the impeller from the shaft of the motor by removing the allen screw with an allen wrench. Seperate pump housing from motor remove the old seal replace seal. Lube motor shaft with a little clean oil or wd40 to facilitate easy install thru new seal,reassemble in reverse.
Posted on Jan 17, 2010
Hayward pool pump leaking from underneath motor
The leak is an indicator the shaft seal has failed. It leaks by design to let you know to replace the seal before water gets into the motor and ruins it. Replace the seal right away.
Aug 17, 2014 | Hayward 3/4hp Super Pump Inground Pool...
Pool motor leak
If you are asking how to replace shaft seal?
open & dismantle pump from motor. Some will have thru bolt motors all the way thru the motor, heads of bolts are (4 each) visible & accessible at back of motor. Loosen these & your wet end will be detached from the motor once the impeller is removed. To do this, block and prevent the shaft from spinning - normally there is access to the shaft which is located at center behind a cap at the back of the motor. Then unscrew the impeller from motors shaft.
Aug 17, 2012 | Hayward 1.5hp Pool Pump Motor Motor A O...
Can't get impeller off proline pump
backwards thread screw then impeller turns off regular if you hold back of motor
Jun 16, 2012 | Hayward 1 12 Hp Super Swimming Pool Pump...
I have a proline 1.5hp pump need to replace the shaft seal. I can't seem to get the plastic impeller off. We use a screwdriver to hold the shaft screw and try to turn the impeller counter clockwise...
Keep trying - It is stuck and will likely break but you have to remove it to change the seal. It is not uncommon to need to replace the impeller when the seal fails since the water gets behind the impeller shaft and rusts the metal causing the impeller to bind. If you still cannot get it free pull the motor thru-bolts and lock the rotor once removed from the motor in a vice. Use a large pair of channel locks to break the impeller free...replace it if necessary.
John
May 15, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
I have a proline pool pump model # SD-15-1N11CC and it worked fine until I back washed my pool and now it stopped working. It makes a humming noise and nothing else.
C. MOTOR HUMS, BUT DOES NOT START—
Check for:
1. Centrifugal switch stuck in open position.or if capacitator start could be bad capacitator. Possible loose connection.
2. Binding of motor shaft. (something stuck in impeller) Does motor turn free. IF not check for jamed impeller. If it she sp2605x7 you can view a manual here:
http://www.haywardnet.com/products/Manuals/pdfs/manual113.pdf
Aug 17, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Proline pool pump SD-1--1N11XB
This sounds like you have a bad seal in your pump and the loose piece is probally a piece on the shaft of the motor called a water slinger. This is just there in case your seal goes bad and leaks water it will spin with the motor and sling the leaking water out and away from the motor so a small leak does not ruin your motor. But you will still need to replace your seal and "O" ring.
Sep 12, 2009 | Hayward 1.5 Hp Northstar High Performance...
I have a proline 2hp above ground pump. A snake
The impeller is still jammed you need to get it cleaned out. You can try with a pair of needle knose pliers if that doesnt work your gona have to remove the pump bolts that hold the motore to the pump pod. Remove the bolts around the motor and seperate it this will give you better axcess to the impeller. Clean it out and try to move it if the impeller will not spin freely with the debris removed the motor has burned up .
Jun 24, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Hayward 1.5 Hp Northstar High Performance Pump Logo
2,687 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
