Question about Panasonic TOUGHBOOK CF-18 Tablet PC
Trying to give wake on lan to cf-18 like our cf-19s
I have a ton of cf-19s that have wake on lan and a few 18s left that i would like to configure to also wake when i power them on through the master. How hard is that to accomplish.
  • michael_free Jun 03, 2009
    Ok next question. How do I actually accomplish this??
    Genius:
  • 1,605 Answers
Not that hard, time consuming task.
BIOS, NIC, Power Option, remote user permission.
which require you to be at the machine. Since you can't do BIOS change via remote.
if all machine are similar, it should take you no more than 10 minutes per machine to set up, and test.
Posted on Jun 03, 2009
  • Frank
    Frank Jun 05, 2009
    1). each BIOS is different, so I cna tell you how and were to set the WOL.
    2). NIC>> advance>>WOL
    3). control Panel>>system>>advance
    select user local and network(need to have full rights).
    4). download magic packet
    5). test it out.
Where is the wireless swith on the cf-19
The wireless switch is behind the PC Card Door located on the left side of the Toughbook 19
Rugged Mobile Technology Panasonic Toughbook Toughpad Tablet Sales...
Jun 16, 2014 | Panasonic TOUGHBOOK CF-18 Tablet PC
Hi when i trying to load os it gives crc error sometimes at 4% sometimes at 18 % please help
Issue:
Cyclic Redundancy Check or CRC error.
Cause:
This error message could be generated by any of the below reasons.
1. During the transmission of the file it became corrupt or bad
2. The file was sent inappropriately
3. The device being opened from is bad or contains errors
4. The file itself is bad or the program attempting to open the file is bad.
Jan 05, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
Internet explorer connection
This problem could be due to your DNS settings or your IP Address. First of all you will have to configure your router to accept the new computer. To do this you will need to go in to the router in your browser window and add your new device.
Then you will need to configure your router to either automatically assign an IP Address or use an allocated IP Address and use the same setting on your new computer. Also, you will need to configure your router to either assign a DNS Server automatically or to use an allocated DNS Server and once again you will need to use the same settings on your new computer.
Your IP Address is crucial in order for your new computer to connect properly to your network. Your DNS Server is crucial in order for your new computer to access the internet through your network.
If you still have problems, please do not hesitate to contact me directly on Skype (Skype Username: fixya-support)
Thank you for using FixYa! Have a great New Year and please remember to rate this solution.
Warm regards,
BearWeb
Jan 09, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Took out HD to reload windows as it would not load but stuck at the safe / last known good config etc. Loaded XP onto HD via an ACER laptop and reinserted it into ToughBook -...
I think your actually having issues getting it to run on the toughbook because it uses different drivers for everything from the Acer computer. If you press F8 while booting up you can choose the option "Disable automatic restart (of system errors or something)". Then when the machine boots up you should get a blue screen giving you an error code like "IRQ_EQUAL_TO_OR_GREATER_X Error: 0x0000005f. You could try to see what the message is trying to tell you to resolve it but the error msg would likely point to the driver that its trying to load that's most likely different from the toughbook you have. I'd suggest getting an external cdrom/dvdrom and install windows from a disc onto the toughbooks hd while its in that toughbook machine.
Dec 21, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
I am trying to calibrate the touch screen and it keeps giving me an error of "Parameter Error. Please input, again."
Your touchscreen is defective. Please contact Panasonic official service center http://heartlandsi.com to arrange a repair. It's covered under warranty.
Sep 23, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Where is this Wireless Switch on the CF-18?
intel proset may have the wireless disabled. go to:
start;
all programs;
intel proset wireless;
in the bottom left of the popup should be an on/off switch. you may get a message saying windows is managing the device but windows could manage getting wet in a shower.
cheers
Apr 03, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Toughbook CF-18 Supervisor Passwd
Toughbook CF18, CF-18
How to remove the BIOS Supervisor Password:
Open all covers and openings. Remove hard drive and battery. Remove bottom of notebook. Many many tiny screws.
Now look towards the rear of the notebook. You will see 2 plugs both have a red and black wires. The one with the much smaller wires and connector is the BIOS battery. Use a pair of needle nose pliers and remove this plug.
Leave it off for 5-15 minutes.
Leave the BIOS battery plug off. Replace the laptop's main battery. Leave the hard drive out. Turn the unit over and turn it on.
Press F2 when the screen comes up. POOF! NO PASSWORD!
Go to Security and disable the password. Save configuration. Turn off the notebook. Replace the small connector. Turn it back over and turn it back on. Press F2 and verify that there is no password. Go to Security and Disable the password again. Save the configuration.
Put the bottom back on. You're done.
NOW FOR THE BAD NEWS!!!
Your hard drive is now dead. Replace it. When a supervisor password is used it locks the hard drive to that password. There is NO WAY to recover the hard drive. It is called an ATA security password. Without the ATA password the hard drive is completely useless.
Nov 10, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
638 people viewed this question
Top Panasonic Tablets & eReaders Experts
Paul Wang
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
